Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 24th February 2013, 06:58 AM   #1361
EUVL is offline EUVL  Europe
I was up at 5:00 this morning. And earlier weekdays.
Enjoy your stay,
Patrick
xen-audio.com
Old 1st March 2013, 02:28 PM   #1362
Bemused is offline Bemused  United Kingdom
Enjoy your stay,
Patrick
Oh boy Patrick, your an expert with electronics but I sure could help you out with that nasty early rising.
The hour of rising is directly proportional to the square of alcohol volume consumed the night before
Will eventually get the Sens in full differential audio next week btw
Old 1st March 2013, 03:07 PM   #1363
4am is the best time for innovation.
Patrick
xen-audio.com
Old 1st March 2013, 04:55 PM   #1364
bcarso is offline bcarso  United States
diyAudio Member RIP
Well although I may not stay up thereafter, I find my own body works differently, more of a reciprocal to the square of ethanol consumed, after a constant is added of order three hours.
It can be useful though to be able to respond to e mail in the earliest morning, giving clients the illusion that one is up continuously.
Old 2nd March 2013, 10:50 PM   #1365
smms73 is offline smms73  Portugal
smms73's Avatar
what you guys think about the 2sk715 from sanyo to substitute the 2sk170 ?
It has higher forward transfer admittance (50mS), and lower gate drain capacitance (3pf). And is also low noise.
http://www.onsemi.com/pub_link/Collateral/EN2543-D.PDF
SÚrgio Santos
Old 2nd March 2013, 11:18 PM   #1366
diyAudio Member RIP
That looks like a nice part, similar to the BF862 but in through-hole. Low voltage however, so that requires some care.
Old 3rd March 2013, 04:36 AM   #1367
Essentially a BF862 in different package, and cost quite a bit more ....
Patrick
xen-audio.com
Old 3rd March 2013, 09:25 AM   #1368
smms73's Avatar
2sk932 is the smd version of 2sk715 and is cheaper.
BF862 has very good characteristics, and higher Vds (20v).
Patrick I am doing some tests with your circuit ( CEN ) , I think it can be very good solution for PCM1794 as this type of DAC has very high output impedance.
The major source of distortion of the CEN with this type of DACs is the gate to drain non linear capacitance of the Jfets, I am trying to come up with a simple solution that do not add much complexity and maintain the excellent stability of your circuit.
SÚrgio Santos
Old 3rd March 2013, 10:23 AM   #1369
The distortion mechanism has been discussed in some detail in my article which you can download (free) from Jan Didden's Linear Audio website.
The easiest way to reduce non linear capacitance is to use SEN with BF862, cascoded with J111.
In Spice simulation, the distortion is as low as -120dB or thereabouts.
But the distortion even in the original SEN is very very low, that you may not hear any difference. More an intellectual challenge.
And cascoding thus make it more prone to oscillation.
Try it out in Spice for yourself.
Patrick
xen-audio.com
Old 3rd March 2013, 10:24 AM   #1370
smms73's Avatar
This is what I have for now. The stage based on 2n4416 act as a buffer between the gate non linear currents of the input Jfet (2sk170 , 2sj74) and the ground.
With a infinite output impedance source the distortion is near zero, with the same conditions the normal CEN have 0.005% because of the Crss non linearities.
The distortion with a input impedance of 200K , 8ma p-p and 6 Volts P-P output is 0.00002%.
I am looking for a substitute for the 2n4416.
SÚrgio Santos
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
