Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 17th February 2013, 12:34 PM   #1341
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by LuisMCP View Post
Hi Patrick,
Why use a Relay instead a simple switch?
The floating supplies need separate "switches" and relays are more convenient as you may control multiple with a single simple switch.
Old 17th February 2013, 12:44 PM   #1342
EUVL is offline EUVL  Europe
Well, one can in theory also use those multi-deck switches as used in the Cordell THD Analyser.
http://www.diyaudio.com/forums/solid...-analyser.html
Patrick
xen-audio.com
Old 17th February 2013, 05:30 PM   #1343
Nikon1975 is offline Nikon1975  Austria
Are normal small signal relay appropriate, as they have to switch DC and signal at the same time. Any Omron series reccomended ?
Old 17th February 2013, 07:27 PM   #1344
NicMac's Avatar
I think Patrick uses Omron G6S.
The relay only switch power (and not signal), but or course that may also affect the signal
Old 17th February 2013, 10:02 PM   #1345
The signal current does not go through the relay.
Check out the current loop from DAC iout to DAC Gnd.
The battery (and hence the relay) is not in that loop, or at least should not be.
Patrick
xen-audio.com
Old 18th February 2013, 11:43 AM   #1346
samoloko is offline samoloko  Bulgaria
Patrick
does 18VAC 1.6 A transformer proper choice for charging 4 x 14 x 1.4 NiMH batteries with one LM317
Old 18th February 2013, 12:44 PM   #1347
Why not make up a simple Spice file to check it for yourself ?
Patrick
xen-audio.com
Old 18th February 2013, 02:21 PM   #1348
LuisMCP is offline LuisMCP  Spain
LuisMCP's Avatar
Originally Posted by samoloko View Post
Patrick
I believe that each stack of 7 cells will "eat" 60 mA. This is 60 x 4 = 240 mA
18V x 0,25 A = 4,5VA and yours is 1,6A x 18V = 28,8 VA
seems OK
Old 19th February 2013, 08:20 AM   #1349
guglielmope is offline guglielmope  Italy
Hello Patrick,
I'm testing my SEN on ES9018 with Salas Shunt PSU.
Everything seems ok, But I'd like to have your suggestion about the shunt current. The total Idss is about 33mA and now I'm using a shunt current of about 70mA.
What do you think about?
Ciao
Guglielmo
Old 19th February 2013, 08:33 AM   #1350
There is no dynamic current in the loop, so in theory 35mA is enough.
I consider 50mA more than sufficient, and 70mA a bit over the top.
But no harm done in any case.
Patrick
xen-audio.com
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
