Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 22nd September 2012, 06:05 PM   #1211
EUVL is offline EUVL  Europe
> but I chose to eat a Shabu Shabu and I am very satisfied with my choice in all regards... so I'm an artist !
You are not, but the cook is, because there are infinitely many ways to cook Shabu Shabu.
Even based on the same ingredients and recipe, you can still do it wrong and then it does not taste so nice anymore.
> What I have seen is prejudice against it...
Do what pleases you.
Just don't complain that your noise problem is a circuit design fault of the IV converter.
Because I don't have the buzz problem, and neither does Nic.
> In fact, in my estimate the SEN-board/Buffalo combo has >10 times the length of non-twisted cabling than has a well done stacked design.
If you put the bottom layer of the PCB close to a grounded conductor, you get effective shielding.
And if you place it at a much larger distance to any disturbance, or even better a Ground plane in between, you can suppress any disturbance pick up.
It is a bit more difficult to shield the cable connected to the digital circuit.
That is why twisted cable there (near the digital board) helps.
Patrick
xen-audio.com
Old 22nd September 2012, 06:32 PM   #1212
needsp is offline needsp  United Kingdom
Hi Nic
Is your layout still as shown here?
http://www.diyaudio.com/forums/digit...ml#post2952599
Mine is here-
http://www.diyaudio.com/forums/digit...ml#post3093382
Yours now seems much better in retrospect- the SEN boards arenít directly over the digital board, and the latter is close to the grounded case work. I suspect our layouts were chosen as the easiest to implement from where we started- mine certainly was, but if you were more prescient, well done! And the fact youíre problem free fits with my hypothesis- not prejudice, LazyButt- that stacking the boards directly over one another may increase the changes of rf pickup/oscillation carrying audio noise into the circuit. Iíll test my hypothesis by putting the Sen boards either side of the Buffalo board, close to the casework. If the buzz is absent, and after trying to provoke it in the ways Iíve described, Iíll tentatively conclude that the altered layout has helped, and that the old layout was more problem prone. Only tentatively, because without knowing the exact nature of the interaction between the boards which provokes the hum- it might involve just the layout of the components and their links, and/or through space interactions, I wonít be able to probe the mechanism in detail. But Iíll be a happy listener
Paul N
Old 22nd September 2012, 06:39 PM   #1213
> But I’ll be a happy listener
That is the only thing that counts.
Patrick
xen-audio.com
Old 23rd September 2012, 08:14 AM   #1214
Lazybutt is offline Lazybutt  France
I'm not complaining, and never have complained about a design fault in this thread (or show me where, and I'll apologize !)
I think however this particular circuit is more prone to RF pickup than others... I don't call that a design fault.. just one of the drawbacks of that particular arrangement. (sorry for the bad word :P)
Actually I suspect my buzz is coming from the Buffalo DAC (and I have some ideas as to why -something to do with a DC imbalance at the output of the ES9018 channels- ... just need time to do more measurements and tests => for sure if I find the answer I'll keep everyone posted)
It seems neither you or Nic are using an ES9018 in Single Ended mode..... or at least I have not read reports of it... that's why I was suggesting that no proper scientific evidence or test protocol has been shown so far...
And again: I don't have a buzz issue in Balanced mode either...
Cheers!
Fred
Old 23rd September 2012, 08:17 AM   #1215
Originally Posted by needsp View Post
Iíll test my hypothesis by putting the Sen boards either side of the Buffalo board, close to the casework..........
Now that's what I call a test protocol !
Looking forward to your findings
Fred
Old 23rd September 2012, 08:28 AM   #1216
Fred,
I was just pulling your leg. Don't take it so serious.
It's hobby, and we should have fun.
We (the xen team) have some evidence of where all these buzz problems (might) come from.
But we make it a point not to criticise designs of others.
The fact that you have no buzz in balanced mode tells a lot.
Patrick
xen-audio.com
Old 23rd September 2012, 08:29 AM   #1217
Calvin is online now Calvin  Germany
Calvin's Avatar
I've just noticed, that the silkscreen of the SEN-board reads "September 2011".
So, Happy Birthday then Baby SEN :-)
jauu
Calvin
Old 23rd September 2012, 08:40 AM   #1218
Thank you.
Even the parents forgot the birthday.
Bad Papa .....
Never thought we could have gone over 1000 posts.
But disappointed so few people have taken the courage to build and find out.
What a pity. They don't know what they are missing .....
Patrick
xen-audio.com
Old 23rd September 2012, 09:51 AM   #1219
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Hi Patrick, forgive me if it's been asked, but what are you using with the SEN as an output buffer?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 23rd September 2012, 10:15 AM   #1220
Hi LazyButt
By SE output, do you mean taking just one phase and ground? This works OK for-me, no buzz at all! (Though Iíll recheck- presumably also ďcapriciousĒ.) Ironic, given the issues Iíve had on occasion with a balanced output, and, particularly, the enormous amount of noise and distortion I heard with any other IV stage Iíve tried- Legato, Ivy, etc. See here-
http://www.diyaudio.com/forums/digit...ml#post3097362
And here-
pink fish media - View Single Post - The art of Sen
Have you compared the two outputs in listing tests? At first I thought them to close to call, but, with more complex material- particularly solo piano- I preferred the balanced out. I run both SE and BAL singles through a Jensen JT-11P-1 line transformer before my single ended line stage- to convert BAL to SE, and to take benefit of the transformerís common mode signal rejection for the SE single.
Best
Paul N
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
