Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
Old 31st July 2012, 05:41 AM   #1091
heb1001 is offline heb1001  China
Originally Posted by bcarso View Post
Do you know what the output impedance of the DAC you are using is?
I do like the idea of correcting for displacement currents in the basic input section without requiring additional voltages. But the problem the approach poses for matching is formidable.
I will post soon, probably in a separate thread, on a repurposing of some of the parts, along with cascode structures, which seems to my Mahayana sentiments, still pretty Zennish. And it's all free range NJFET
Brad
Not sure on the PCM1794A output impedance. Think it is quite low - maybe 1K ish.
With #998 (and to a lesser extent #908) you can parallel up pairs of JFETs to get the I/V input impedance down as far as you like without making the distortion worse since the gate current to ground doesn't increase.
Matching wasn't any harder than for Sen - I just picked pairs that were matched to .01 mA Idss.
I think the problem is high frequency noise - I think it does a bad job rejecting noise coming in from the output and it may have been oscillating at high frequency I'm not sure.
I have a wireless mouse and I did notice that when #998 was switched on I was getting two mouse clicks registered every time I pressed the button - that can only be a bad sign.
I'll try adding a resistor to see if I can calm it down a bit.
Old 31st July 2012, 02:10 PM   #1092
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Originally Posted by qusp View Post
yes Dirk, but the actual working voltage of batteries IS pretty stable and does not vary anywhere near that much. most batteries will drop fairly rapidly from their fully charged state (which is above the nominal voltage) in the first short while, then remain pretty steady for ~75% or more of their charge, dropping a fairly small amount, then drop rapidly again at the end of their cycle.
At such low discharge rates as we are using here, they are MUCH more flat again; use them within their plateau and cut off before the sharp drop.
Well, if the actual voltage isn't that critical to your design, then batteries could be ok I guess. They still produce noise though. They are not noise-free.
Also, I was under the impression that the jfets in this design were running at Idss, which for these is anywhere north of 10mA. You'd double that for paralleled jfets of course. The rechargable 9V batteries have anywhere from 100 something mAH to over 500, so that's something like 10 to 50 hours of running, but towards the end the voltage drops dramatically. I assume the plateau is far shorter than that.
So, I don't see the attraction to batteries, sorry.
Old 31st July 2012, 02:44 PM   #1093
qusp is offline qusp  Australia
qusp's Avatar
actually no, the plateau at this low current is the majority of the charge, only at the very end. at the risk of enraging Patrick i'm just going to link an image. at such low current the drop is much more severe, it will be almost flat and then drop like a stone at 10-20ma, its really not worth worrying about.
the attraction to batteries is avoiding all of the issues that have been discussed over the last however many pages. they come with their own issues of course, but they have plenty of advantages and the vdrop is a complete non-issue in this build.
of course they arent noise free, but the noise is very low and there is a complete lack of mains ripple
Old 31st July 2012, 03:13 PM   #1094
dirkwright's Avatar
Here's an article on batteries vs. regulated supplies:
Simple Voltage Regulators Part 1: Noise
This particular circuit (Zen, etc.) is sensitive to the output impedance of the floating supply. Unless the batteries are heavily bypassed, the source impedance will have a negative effect on the performance of the circuit. The circuit requires that the floating supply cancel out all differential mode signals and the only way to do that is to make sure it is a dead short for AC signals.
I do not know where you are getting 9 volt batteries with that high of an amp hour rating. According to Wikipedia, these kinds of batteries have much lower amp hour ratings:
Nine-volt battery - Wikipedia, the free encyclopedia
Please note that I am talking about ordinary 9 volt batteries, not huge and very powerful battery packs made from a bunch of high capacity NiMH cells. I think it's plainly obvious that hooking up say a 12 volt car battery to this circuit is not going to have an issue with a 10-20 mA load.
Old 31st July 2012, 03:28 PM   #1095
EUVL is offline EUVL  Europe
I am sorry, but the SEN / CEN IV are completely different circuit principle than the ZEN IV, as already explained in the article.
Really ?
BTW, have you actually built and tested one ?
Patrick
xen-audio.com
Old 31st July 2012, 03:56 PM   #1096
NicMac is offline NicMac  Italy
NicMac's Avatar
I agree - I also see absolutely no attraction to batteries.
However, with SEN I so very clearly hear the attraction to batteries, that I am considering to implement them much more frequently in my builds.
Old 31st July 2012, 04:11 PM   #1097
bcarso is offline bcarso  United States
diyAudio Member RIP
Yes, the subtle benefits are significant. And with cascode structures, although the voltage burden is higher, the noise in the batteries is virtually irrelevant.
It amuses me a bit to see people complaining about the hazards of noise pickup with batteries, yet claiming that floating mains-powered supplies should be trivial. It's true that with great care and lots of good common-mode chokes, mains supplies can be sufficiently good --- but it's a lot of trouble.
Old 31st July 2012, 04:13 PM   #1098
Actually Nic, you can do an experiment for us.
Add a series resistor to the battery between +V battery and +V circuit.
Say 1R.
Run the SEN IV to play music (or signal).
Measure the differential voltage across the 1R resistor.
(You need a differential probe or 2 scope channels and then subtract.)
I bet you will see DC only.
The circuit is designed such that the current draw on the batteries are constant ( = Idss of matched FETs).
And then you can also listen for any "detrimental" effects of the 1 ohm resistor.
Must be a very poor battery with internal resistance of 1 ohm !!!
Patrick
xen-audio.com
Old 31st July 2012, 04:33 PM   #1099
Me too. It's only 375 cells to get B+ for my amp!
Old 31st July 2012, 04:45 PM   #1100
qusp's Avatar
I posted the graph to simply show the discharge curve of NIMH and how radically it changes with lower currents and I fail to see how a higher capacity battery will behave any differently at such low currents. myself I use much higher current single cell lifepo4 cells that put the above graph to shame as far as current, but NIMH are no slouches either. basing your argument on zero experience and decades old research is pretty meaningless i'm afraid.
I wonder when people who have no experience of using quality batteries in their gear will stop quoting that article to back up their present day arguments? its getting pretty tiresome, the number of times its been covered is right up there. I dont have the gear to test or I would be answering the call to update it.
also notice the voltage scale on the side, this is not a big battery
AC and batteries and switching supplies all have pros and cons, areas they do well and others where each is a pita, but low current low noise line level gear is most definitely an area where batteries excel
Zen -> Cen -> Sen, evolution of a minimalistic IV ConverterHide this!Advertise here!
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball prooptiki Swap Meet 1 22nd May 2010 05:57 PM
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A novec Digital Line Level 11 11th May 2010 11:57 AM
> Audio <> music <> quick <> synergy <> angst>? rick57 Everything Else 0 4th May 2007 04:03 PM
&gt;&gt;&gt; cheap 50,000uF 60V capacitors here &gt;&gt;&gt; Lubomir Swap Meet 0 1st February 2007 03:36 PM
