Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#101 |
For Joachim's circuit in post #99, THD is 0.0016% in Spice.
- Without 4x 370R loading resistor, THD is improved to 0.0012% for lesser voltage swing at input FET drains. - Without the 4 helper BJT, THD is increased to 0.003%. - Without 2x 50k feedback resistor is THD is 0.0021%. So plenty of choices, whether to go for simplicity or the last few dBs THD. We'll stay with the Wilson mirror for now. I think I had a thinking error with Calvin's circuit. I think I get it now about the biasing. My apologies to Calvin. Still, my prejudice remains against exponential devices. But I guess the real test is a listening test. See if I have time to put a proto board together, using 3 separate supplies. Patrick |
#102 |
Thanks for simulating. I only have simple math in my toolbox. I studied electronics in the 70th where even a pocket calculator was forbidden. I failed my promise by a factor of two. Could it be that noise performance could be compromised without the loading resistors ?
#103 |
Joachim,
A member of my team did the sim, not me .... ![]() I think it is just simple Spice with perfect resistors, so noise is not taken into account. If you want to know more, please send me a email via the forum. I'll get you in touch with him directly so that you don't have to talk via me. Of course I want to be on the copy list to know what is going on ... ![]() Shall be travelling tomorrow, so no email then. Patrick |
#104 |
Noise plot of Joachim's circuit.
Upper trace, without load resistors. Lower trace, with load resistors. Joachim is right of course. Noise performance is much better with load resistors. Patrick |
#105 |
This outcome may surprise some. Adding resistors lowers noise, but thats the way constant current sources and mirrors work.
#106 |
Euvl ..
could I ask you to post the LTspice circuit...in a zipped folder.. would like to play a little with that and Joachim's RIAA...based on the same Idea... Thanks |
#107 |
Just for the fun, a(nother) BJT version.
#108 |
You mean you want our asc files ? |
#109 |
Some more noise simulations for the original SEN & CEN.
Hard to beat a pair of FETs on their own. Patrick |
#110 |
Yes.. I can see you have the models for the small transistors.. I have already modeled the circuit, but have some trouble with the balance.. would like to see how that changes with your small transistor models...
Thread | Thread Starter | Forum | Replies | Last Post |
FOR REGA Turntable>>> The heavy weight + Vta adjuster+ceramic ball | prooptiki | Swap Meet | 1 | 22nd May 2010 05:57 PM |
Multi-DAC: Lynx AES16 -> DIR9001/SRC4392 (-> SRC4192) -> PCM1794A | novec | Digital Line Level | 11 | 11th May 2010 11:57 AM |
> Audio <> music <> quick <> synergy <> angst>? | rick57 | Everything Else | 0 | 4th May 2007 04:03 PM |
>>> cheap 50,000uF 60V capacitors here >>> | Lubomir | Swap Meet | 0 | 1st February 2007 03:36 PM |
New To Site? | Need Help? |
