TI USB DAC - PC side
Old 19th August 2011, 04:38 PM   #1
srubin is offline srubin  United States
Default TI USB DAC - PC side
I'm pretty new ate this and my question might seem really basic, sorry...
If i build a device with the TI Audio USB DAC (like PCM2704), when I connect the circuit to teh PC, does teh PC immediatly recognize that this is an audio device and starts sending audio to it. or do I need to prepare some software for the PC side?
Please excuse my beginner level.
thanks
Sam
Old 19th August 2011, 08:33 PM   #2
5th element is offline 5th element  United Kingdom
5th element's Avatar
All the details requiring the USB interface and how to configure the hardware.
This is the important part I believe though.
D+ should be pulled up with a 1.5-k Ω ( 5%) resistor. To avoid back voltage in self-powered operation, the device must not provide power to the pullup resistor on D+ while V BUS of the USB port is inactive.
If the device is being powered by the USB cable then D+ is only pulled high when the USB cable is connected, so no special measures need to be taken.
However if you are going to power it from a dedicated separate supply then you will have to provide a logic gate that will only pull D+ high when the USB cable is plugged in. In my implementation I have it set so that when the standard 5volt line of the USB cable is plugged in D+ is pulled high via a logic gate.
Providing you've done what is necessary then yes, as soon as you plug the device into a USB port the computer will recognise it as a generic USB sound controller, it will install the required device driver and the chip will start functioning. In some situations you might have to tell windows that the USB sound card is to be used as the primary sound card for it to work with some applications.
One word of warning though, I have had a situation where the PCM270x wasnt recognised by a laptop and I could not figure out why. Same copy of windows, same service pack with the same drivers as another PC, except it would not work with it. On all other machines and laptops no problems and this was self powered rather then relying on the USB line.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 22nd August 2011, 12:40 AM   #3
That should have read -
All the details requiring the USB interface and how to configure the hardware are in the datasheet.
Old 22nd August 2011, 01:16 AM   #4
Thanks! very helpful
TI USB DAC - PC sideHide this!Advertise here!
Can Tablet PC (android) drive an USB DAC? Aiace PC Based 46 30th August 2013 11:51 PM
How to: Wireless - PC to USB DAC? fork Digital Source 14 11th April 2008 10:58 PM
Is there a usb dac out there that does not need a pc tinears02 Digital Source 3 21st March 2008 05:33 AM
Connect old PC Drive CD-ROM to my USB DAC ? mafioso Digital Source 8 21st October 2007 06:16 PM
USB powered NOS USB DAC with built-in headphone amp dsavitsk Digital Source 15 10th August 2006 06:11 AM
