Capacitor at voltage DAC output
There´s 2v DC on the DAC´s output,the trafo or the caps blocks the DC so it wont reach the preamp or the amplifiers input.
Just make a virtual ground with two resistors from the plus voltage to ground. The midpoint are at the DAC output voltage.
50 or 100 ohm works OK.
A JFET buffer makes it even better, but the resistors alone sounds much better than capacitors or transformers.
You mean
Out - ---100ohm----__ Output to preamp
AK4398 Out + ---100ohm----
Sorry but it gets distorted when I posts.
Hope you can se what i mean.
One resistor from the DAC PSU +voltage to virtual GND.
One resistor from the virtual GND to the real GND.
The virtual GND (midpoint between the resistors)
will now have the same voltage DC potential as the DAC outputs.
The "real" GND must not be used as it is the virtual GND you connect to your amplifier.
