| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hello,
from time to time I fry something... ![]() I was experimenting with various caps used in C378, C379 (CXD9521Q DAC digital decoupling, socketed) when, inserting a pair of Panasonic FM taken from my parts drawer, I've seen some little sparkles... Damn, they were still charged! :O Obiously the player was turned off but when I've powered it on no sound at all, completely mute... I've taken some measurements and all seems fine, according to the Service Manual, except one on the DAC chip (see attached image). It seems probable that the DAC is gone but if all other measures are correct how much hope there is it's the only one fried? I'm correct saying that the wrong measured voltage is an indicator of the fault of the chip? Thanks in advance to everyone that will try to help me troubleshoot ![]() PS In the attachment in green the caps that made sparkles, in blue the good measures, in red the wrong one
Dario ClaveFremen "Bailando Salsa en el Sietch" Last edited by ClaveFremen; 16th August 2011 at 02:19 PM. |
#2 |
I would say the DAC IC is damaged if you saw sparks soldering in new caps and things are now silent
The caps have 22 ohm resistors to the regulators, so most of the voltage spike probably went to the DAC IC. Did you do any other mods at the same time?Checking pin voltages with a multimeter, it is hard to know if an IC is bad. An oscilloscope is a bit better, but there are thousands of transistors inside. C379 is for DVDD (3.3V) and C378 for DVDD (5V?). Note the pin voltages are listed UNDER the pin. Pin 45 is 5V, not pin 46 which (Rch) should match pin 59 (Lch) at 2.5V and you getting 2.25V on pin 46 does not say much. I would see if IC302 is running hot and use a scope to look at signals on the pins. The voltage reg IC312 is ok? Or just change the DAC IC. |
#3 | ||||
Hi prairiemystic,
first of all thanks for the answer ![]() Quote:
)No, I didn't other mods, I was testing several caps in those two positions thanks to sockets. Quote:
I've searched the web for IC302 and it's not cheap and also I'm not sure abot the digital filter and I don't have yet an oscilloscope so I've brought it to a Sony Service Center two days ago...
Dario ClaveFremen "Bailando Salsa en el Sietch" |
| Have I fried an OPT? | theskintman | Tubelab | 3 | 10th January 2011 10:09 PM |
| might have fried my reciever Help Please | gixxierific | Digital Line Level | 4 | 17th October 2008 10:35 PM |
| Fried X-over | Zen Mod | Multi-Way | 24 | 24th November 2006 12:12 AM |
| Fried t-amp? | kaban | Class D | 24 | 23rd June 2006 09:03 AM |
| Page generated in 0.09606 seconds (76.59% PHP - 23.41% MySQL) with 11 queries |
