Making custom 15pin control pod?
Old 30th July 2011, 10:14 PM   #1
sabbathcrazy is offline sabbathcrazy  United States
Default Making custom 15pin control pod?
I have some old z-680 speakers laying around. I saw a add on Craigslist for a z-2300 subwoofer. It does not have the control pod, I want to use my old z-680 control pod. Both systems use a 15pin setup. The Z-680 control pod is digital http://images.viper007bond.com/compu...tech_z-680.jpg
and the z-2300 is just a basic volume and bass knob. I have some schismatics for a custom z-2300 control pod.
http://blog.jseaber.com/wp-content/u...remoteV100.pdf
This is the z-2300 setup
Pin PCB Name Description 1 SLINE Subwoofer Line Input 2 (unused)
3 SGND Signal/Audio Ground 4 PGND Power Ground 5 STDBY Standby, Active Low 6 RL Right Line Input 7 (unused)
8 (unused)
9 (unused)
10 (unused)
11 RHP Right Headphone Output 12 LL Left Line Input 13 LHP Left Headphone Output 14 (unused)
15 VREG 15V Supply Railhttp://blog.jseaber.com/2010/02/27/logitech-z-2300-control-pod-disassembly/
This is what it says on the z-680 circuit board. I need to know witch one to match on the z-2300. I am going to cut the wire from the 15brong connector and rearange the wires so that they match the right hole. Do you think this will work? Consider this. The Z-680 pod is digital and only has one knob. Will I be able to turn down the base using this controller?
1. +8 J6
2. G
3. SB
4. G
5. RR (right
6. Rl (left
7. C (center
8. S (subwoofer)
9. FR (Front right
10. FL (Front left
11.G
12.G
13.-18
14.G
15.+18
I need to match the z-680 pins with the z2300 pins.
Making custom 15pin control pod?Hide this!Advertise here!
Need help with making a port for a custom enclosure. the cobbler Construction Tips 2 16th May 2011 08:02 PM
WTB: Control Pod for Logitech Z5400 starfox Swap Meet 0 15th January 2011 10:40 AM
Cable diagram for connecting to Logitech Z5500 w/o Control Pod JeremyWinston Subwoofers 1 25th November 2010 03:56 PM
Connecting old z5500Logitech Control pod with newer amp/sub mause Chip Amps 0 22nd May 2009 01:50 PM
Custom Remote Control SteveS2 Everything Else 9 7th April 2009 02:04 PM
