| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
Hi all, been reading a lot on this forum recently and really learning a lot!
I'm looking for suggestions for a DSP unit to put into my hifi setup in order to integrate a new sub and make room corrections etc. I've used the Behringer DCX for PA applications and been happy although i've always thought its noise floor would make it unsuitable for hifi. Bss Soundweb (green or black) is another option as is XTA dp200. Have any of you had experience with any of these units in the home? Are there any other units I should be looking at? Thanks Mikey |
#2 |
I am tempted by the miniDSP 2x8 or 8x8 offering. Home | miniDSP
I have a 5 way but could prob get away with 4 way and add tweeter on top. After lots of measuring I would like to try correcting the tapped horn sub and bass horn and take it from there. It would have to be their higher bit rate offerings. There's some good miniDSP threads on here too. The other one is DEQX but that is currently just 3 way and to go 5 way you need to chain 2 together and it ended up at 4-6 grand - gulp! I'm still a bit precious about my analogue signal and my own quality dac that I like though... I have no connection with any of these BTW. |
#3 |
To use miniDSP in Hifi, you should consider to add miniDIGI cards for spdif in/out.
This enables you to use DAC and ADC of your own choice. Franz |
#4 |
Main thing to bear in mind is that all the pro units will need either a preamp that drives them to appropriate levels, or modding to suit lower domestic hi fi levels. The BSS units are very good, (I use them a lot at work), but the Soundweb is fiddly to program as you need a PC, and the DPA200 is only a 2x4 unit, so for anything other than 2 way stereo you will need multiples. I have a (currently) unmodded DCX at home, and driven appropriately, the noise floor isn't a huge issue. Personally, if I had the cash, I'd go for a XTA DPA448.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 | |
Had a quick read - looks like quite a bit of kit.
As you say - if one had the money... Quote:
#6 |
How are you finding this? I'm guessing the (currently) means you have plans for a change in the pipeline? I'm assuming that as you've not modified it you have a preamp in between your source(s). Apologies for the number of questions, I'm just pondering on whether the berry will play as nicely with my hifi as it does with my PA gear.
#7 |
Well, I knocked together a quick DRV2134 circuit to drive the DCX after my valve line stage to sort out the level issues, but in the long term I'm going to mod the input and output stages so it's more home friendly, and probably build a multichannel volume control for the output to optimise gain structure.
#8 |
I have a minidsp 2x8 and I have to say it is a fantastic piece of kit. The internal dac sounds excellent, the filters are versatile and the noise floor is ultra low. I'd recommend it any day. I had previously looked at 2x4 versions but they weren't versatile enough for me as I want 3 way plus sub crossovers and would have needed two.
Jai |
#9 | |
Great, just the kind of report that's good to get.
They certainly are pretty versatile. What other kits pre and after DSP are you using? Quote:
| KTA-HiFi ST-70 pcb or marantz 8b. HiFi build | iglehart332 | Tubes / Valves | 18 | 18th March 2011 02:19 AM |
| New to DSP | Ridin '24'z | Digital Source | 5 | 12th May 2010 01:33 PM |
| RS-232 cable for DSP-Amp Digisynthetic DSP-1400 | Sabbelbacke | Parts | 0 | 9th May 2009 09:33 AM |
| dsp chip | leosedf | Digital Source | 1 | 3rd December 2003 12:34 PM |
| DSP theory | hifiZen | Digital Source | 7 | 6th November 2001 06:18 AM |
