Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th July 2011, 07:00 PM   #1
Default Silicon Labs 530 low jitter oscillator
Anybody any experience with this osc?
Reportedly it renders better results than Tent Clock..
Old 27th July 2011, 11:06 PM   #2
iancanada's Avatar
I did. Very good.
Table 4. CLK± Output Phase Jitter
Phase Jitter (RMS) for FOUT of 10 to 160 MHz CMOS Output 12 kHz to 20 MHz (OC-48) 0.62 ps 50 kHz to 20 MHz 0.61 ps
Table 5. CLK± Output Period Jitter
Period Jitter* JPER RMS 2 ps
Peak-to-Peak 14 ps
Old 28th July 2011, 02:22 PM   #3
While I haven't experimented with this device, I remain unimpressed with it's specifications for digital audio application. First, there is no phase noise plot shown, only a few cardinal point specs. Second, close-in phase noise is only given for carrier frequencies of 120MHz and above, and even then, not at a 10Hz offset. Third, at carrier frequencies useful for audio (10MHz rage), phase noise is only given down to a 12KHz offset.
So, is this a superior oscillator for digital audio purposes? Maybe, but I think that is not a fact established in the data sheet.
Ken
Old 28th July 2011, 04:34 PM   #4
glt is offline glt  United States
I plotted the phase noise (from the datasheet) for several oscillators including the silicon labs part:
H I F I D U I N O: Clock in Buffalo II DAC
The data is limited to what is available in the data sheets, but since the phase noise curve follows a known pattern, you could extrapolate...
www.hifiduino.wordpress.com
Old 28th July 2011, 04:54 PM   #5
jcx is online now jcx  United States
the NEL does look llike the best so far
Originally Posted by jcx View Post
...Crystech makes xtals in std DIP cans with better than -120 dB@100Hz, -140 dB@1Khz
if you want to throw money at the non-problem then Vectron EMXO series evacuated SC cut with low vibration sensitivity may make more sense - they claim to be able to "significantly" better the -130 dB@100 Hz close in noise on request - but you'll probably have to pony up for a 100 piece min order
when human jitter perception in audio is looked for in DBT studies the sensitivity is absurdly low - 100s of nS - not ps
Low distortion oscillator? rjm Equipment & Tools 30 4th May 2011 10:45 PM
Low jitter 30MHz crystal oscillator? Kuro Parts 2 1st April 2010 12:27 AM
Any Fab Labs left in Texas or Silicon Valley? roddyama The Lounge 13 30th April 2004 01:03 PM
Low-noise oscillator Jocko Homo Digital Source 50 27th March 2003 03:35 PM
Page generated in 0.08378 seconds (76.74% PHP - 23.26% MySQL) with 10 queries
