| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
There is a common NOS PCM56 scheme where Fsynk in is inverted for the right channel PCM56 with an 74HC04. The problem is this introduces a prop delay on the right channel vs the left. There have been many schemes suggested with the only real solution being a programmed fpga which is out of reach for most DIYer's.
What about substituting the 74HC04 with a NL17SZ04 ? Would this faster part make the prop delay inconsequential? |
#2 | |
#3 | |
Anyway it is intersting you find the simple approach sounded better, and now there is a faster single part simple solution that I am thinking it may be worth a try for an NOS DAC using a chip you can still buy from Mouser. Always been a PMD100 DAC person looking to try somehing different. Here is some advice I saved from one of the NOS disciples (I am guessing the TDA1541 specs are for double crown): DAC THD&N SNR AD1865 - 88dB -110dB AD1862 - 98dB -119dB PCM56 - 94dB -110dB PCM63 - 92dB -120dB PCM1704 - 92dB -120dB TDA1541A -100dB -110dB TDA1543 - 75dB - 96dB TDA1545A - 88dB -101dB Seeing this table shows the TDA1541A as actually having the lowest THD & N at full scale. The AD1862 and PCM56 are second and third respectively, followed by the newer BB PCM Chips and with the AD1865 and TDA1545 bringing up the rear with the almost poorest performance, but that honour actually goes to the TDA1543. So, my first suggestion, if one is desirous of a high quality NON-OS DAC is to select one that uses DAC's that have a low THD & N, which seems to limit us to TDA1541A, PCM56 and AD1862. It would also seem that it is best to avoid the TDA1543, and probably too the TDA1545A and the AD1865. |
#4 |
Most standard specs are meaningless, especially for DACs
Let me elaborate: TDA1543 a little harsh TDA1545 very un-involving AD1955 no depth, no bass slam PCM56 does have bass slam, but AD1851 has better highs AD1865 often shows irritating glare...but has bass. etc. etc. On top of that the used IV-converter can make or break the sound. ![]() Square wave is always perfect NON-OS no matter what method to get left-right separation
#5 |
Thanks for sharing your impressions. My experience is mainly all PMD100 OS'd: PCM63K, AD1862J, and PCM1704K. I too have found that the analog stage is very influential, but I have also never found an off the shelf digital filter I like besides the PMD100. My only experience with NOS was a poorly designed TDA1543 which literally stopped at 12khz, every tone above this was pitched down to 12khz.
But recent attempts with different Hirez digital filters all failing to satisfy as the PMD100 has me thinking of revisiting the NOS design. I mean trying these different filters, some different revised FPGA firmware on the same DAC has me thinking maybe no filter is best. Or I may try serial programming a WM8741 to hear its 6 different OS algorithms. Too bad we DIYers can't buy the expensive Blackfin type filters used in new DAC's like the Berkley Alpha, Meridians, Cambridge, etc. |
#6 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
You don't need to go to Blackfin to do digital filtering - I'm running a clone of an SAA7220 on an LPC1114 at the moment. So maybe that part is an answer to your prayers - its cheap (under $2) and the tools are in the main free.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
| 4 Nos RCA 8417 tubes NOS | battradio | Swap Meet | 3 | 20th January 2012 01:02 AM |
| my PCM56 problems | mojsa2000 | Parts | 0 | 7th July 2011 02:19 PM |
| Some ECC83's nos & 2 E280F's nos | Westerp | Swap Meet | 0 | 26th May 2009 10:00 AM |
| Pcm56 Nonos | Calamaro | Digital Source | 4 | 19th July 2008 03:10 PM |
| tda1541 vs. PCM56 | Bernhard | Digital Source | 23 | 21st October 2004 10:42 PM |
| Page generated in 0.10455 seconds (80.65% PHP - 19.35% MySQL) with 10 queries |
