PCM5102, 2VRMS ground centered direct output with two digital filters
Old 17th May 2012, 04:24 AM   #51
EUVL is offline EUVL  Europe
Out of curiosity, I did some measurements.
In my setup, the PCM5102 uses a 45.15MHz XO, 3.3V power supplies (3x), and has I2S input at 16 bit 44.1kHz.
The measured signal is taken directly at the IC output pin, without the datasheet 470R-2.2nF low pass filter.
Indeed there is clipping at the negative rail at full 0dB output.
The charge pump does not generate the full -3.3V, and hence the output opamps run out of voltage.
The clipping is gone for -1dB signals. And this can be solved without too much effort even for 0dB.
A similar problem exists also for the ES9022, which is why they brought out the 9023 to run on +3.6V supplies.
In real music material, this (0dB signals) hardly occurs.
Or at least in my own CD collection, I don't have anything that goes the full output amplitude.
We shall certainly continue to play around with this.
I particularly like the low latency filter.
Patrick
xen-audio.com
Old 17th May 2012, 01:43 PM   #52
Very quick & dirty, but problem solved.
I forgot to mention that the output was loaded with a 600R load in my setup (headphone with series resistor).
The charge pump generated -3.16V with a +3.3V supply, and is somewhat load dependent.
So loading it less (say RL 0 10k) will probably also remove the "problem".
Back to some more listening .....
Patrick
xen-audio.com
Old 17th May 2012, 01:50 PM   #53
linuxworks is offline linuxworks  United States
linuxworks's Avatar
the clipping I refer to is NOT analog based.
it happens when you run too hot a DIGITAL signal to the chip. that's what gibbs is all about.
this was never a PSU or buffer issue, at least in the problem I was having.
My Photostream:http://www.flickr.com/photos/linux-works/
Old 17th May 2012, 01:51 PM   #54
I do not consider e.g. a 0dB square wave to be a realistic music signal, if that is what you were referring to.
Patrick
xen-audio.com
Old 17th May 2012, 09:01 PM   #55
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
It seems a flawed product when digital and analog clipping can occur (but a 0 dB square wave is indeed unrealistic).
Probably is not enough.
It's only audio. Member of the non modular PCB design committee
Old 17th May 2012, 09:10 PM   #56
The "analogue" clipping was gone when I removed the headphone and changed back to 10k load.
I have not seen any evidence of digital clipping, and there are no other similar reports on the inet.
No test conditions, no oscilloscope plot, .....
I just spent 5 hours listening to it.
It is going to take the place of my ES9022 for a while.
Patrick
xen-audio.com
Old 17th May 2012, 09:15 PM   #57
jean-paul's Avatar
Have fun with it ! That's what it is about. I will go on with ES9023 on 3.6V for a while. I still have to compare with FN1242a.
BTW data sheet of PCM5102 says it can be loaded till 1 kOhm so there is something not right here...
Old 17th May 2012, 11:13 PM   #58
linuxworks's Avatar
the cd (flac) I was listening to was not a function generator output, lol. maybe I should cut a sample and post it so that others can try. artist was loreena mckennit and there were some very low bass notes that, along with the music, just seemed to sum up to a very high near-zero level. hey, its how they are mixing and releasing music these days; expect more and more of this problem, not less and less ;(
at first I thought I had a bad rip. it was that bad. was it my phones or phones amp? the dac? the player? man, it sounded bad. I had to verify it all and it sure looked like the badness went away when I kept everything BUT the dac.
so, maybe a sample/clip would help. I'll try to do that. what's the legal limit on how much I can clip and post for demo use? is 10 secs of music enough? that might be enough to show the bug.
(for those that have LM's cd's; its the ancient muse cd, 2nd song).
Old 18th May 2012, 03:49 AM   #59
Send me a email, and I'll give you a email address to send the clip to.
I will then repeat your test and report back.
I have as much an interest as you to find out the facts.
And if it can be proven, we could file a complain to TI and let them sort it out.
It is a good product otherwise.
Patrick
PS Please send me in WAV and not FLAC.
I cannot play FLAC.
Or try playing WAV and see if you still has the problem first.
xen-audio.com
Old 18th May 2012, 03:52 AM   #60
My phone is 200R, and it has a 240R series resistor.
So a bit less than 1k.
In normal line level use, it is no issue at all.
So I consider this academic.
You can also use a 3.6V supply and the "problem" is gone.
Patrick
xen-audio.com
PCM5102, 2VRMS ground centered direct output with two digital filtersHide this!Advertise here!
great digital filters? audiophail Digital Line Level 1 20th December 2010 04:35 PM
Any new digital filters ? percy Digital Source 17 20th July 2008 12:39 AM
Using a passive direct box to kill ground loop noise? Glowbug Tubes / Valves 10 18th March 2008 01:05 AM
Ground Sound- Interesting active filters? weedogt Multi-Way 22 25th July 2007 06:33 PM
