Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 15th September 2012, 06:50 PM   #981
qusp is offline qusp  Australia
qusp's Avatar
sweet!! done deal, for me (apart from multichannel =) thats the last piece of the puzzle, well just one more, transformer isolation of Mclk->Dac but thats easy enough to implement oneself. the man is quick as lightning!
Old 15th September 2012, 08:43 PM   #982
vzs is offline vzs  Europe
Nice indeed, done well I wish I can be half as fast as Ian is.
Old 16th September 2012, 03:19 PM   #983
bigpandahk is offline bigpandahk  Hong Kong
Hi Ian
I connect the USB WaveIO to the FIFO via the SPDIF TTL input but doesn't work. No Lock on FIFO. I use scope to check the non-isolated SPDIF output of WaveIO and can see 5V TTL pulses. Any suggestion on trouble shooting?
Old 16th September 2012, 06:07 PM   #984
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by bigpandahk View Post
Hi Ian
1, Please make sure the TTL s/pdif connections: signal to signal, gnd to gnd.
2, Please makse sure the button on the spdif board was pressed with TTL LED is lighting.
I confirmed this function without any problem by connecting to a s/pdif output of the CDROM.
Good luck.
Ian
Old 17th September 2012, 12:37 AM   #985
smoothlondoner is offline smoothlondoner  United Kingdom
Any more progress on the project,
very interested in the results
james
Old 17th September 2012, 04:54 AM   #986
Good luck.
Ian
Ian
Thanks for your reply. There is no mark on the PCB showing the polarity of the TTL input.
Old 17th September 2012, 04:35 PM   #987
qusp's Avatar
check with multimeter, the TTL input isnt transformer isolated. the right hand pin when looking at the input is ground. also you can fairly easily spot it as ground by looking under the board, notice this pin is visibly connected to a ground plane.
Old 17th September 2012, 05:28 PM   #988
cracra is offline cracra  France
Default FIFO Latency Automatic Minimization
Hi Ian,
Would it be possible to minimize automatically the FIFO Latency (i.e. Minimize the number of PCM samples stored within the FIFO Memory) according to the sampling rate of the incoming Digital audio stream through I2S ?
The reason of my question is that I am using my DAC equipped with the FIFO to convert the audio stream of the movies I watch with my Blu Ray player. Currently the FIFO introduces roughly 2 seconds of latency between the image that is displayed and the associated movie dialogue or sound.
Thanks,
Old 17th September 2012, 05:39 PM   #989
zinsula is offline zinsula  Switzerland
zinsula's Avatar
You'll still need a delay as your clocks will hardly be that equal to allow for very small buffers, i.e. small latency.
To me, even quite small latency is somehow irritating.
Unfortunately, my Video Player does only allow for an added delay of the sound, and not vice versa.
You need a video FIFO, a "latencizer"
If you can't trust your ears, then CLICK HERE
Old 17th September 2012, 06:18 PM   #990
qusp's Avatar
simple answer, no, the best you can do without delaying the video and still using fifo would be to upsample everything to 384khz so it doesnt take as long to fill the buffer. its part and parcel of fifo, being that its a buffer, to have a delay … Without a way to delay the video, its an unwise choice for a video system
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1397 Today 09:01 PM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3167 7th December 2017 08:37 AM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 01:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 10:22 AM
Copyright ©1999-2017 diyAudio
