| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#741 |
Hi Ian,
Ok, thanks for your answer. That's seems I will try this way (I will add an spdif board). That is really nice to find all this good documentation. |
#742 |
Contributor
#743 |
Because of the internal ASRC architecture, Sabre ESS DACs are quite sensitive to the jitter from the input signals. Both async mode and sync mode are. I like this adapter. It’s kind of perfect solution to introduce higher quality U.FL connectors into BIII DAC. But still not as good as DAC which comes with U.FL sockets originally placed on the PCB.
I did some test with this new adapter on my BIII yesterday. It works very well. I’ve noticed some improvement: With BIII (DPLL bandwidth set to lowest) working with I2S FIFO at SYNC mode, If feeding signals with this adapter and U.FL cables, DPLL locks solid never lost; However, without this adapter and U.FL cables, it will lost lock occasionally(every 10 minutes roughly). The BIII input adapter has 9 U.FL footprints, can support all modes: Multi-S/PDIF, Stereo I2S, Multi-channel I2S, or multi-channel DSD. I attached some pictures below just show how the adapter works. Actually the BIII input adapter and the clock adapter were integrated into one PCB. So usually, they come as a set. I’ll supply each FIFO user from GB II one set PCB for free. But to assemble them perfectly is a challenge. Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#744 |
is choosing a less facetious title...
looks good Ian, yep, native u.fl/w.fl connection ftw! i'll have to buy one maybe 2 from you if you dont mind
#745 |
BIII didn’t design with SYNC mode originally. But with this small adapter, it can now. Thanks for the backdoor under the original XO footprint.
Assemble the adapter first. Then remove the CCHD950 from BIII PCB. Solder the three pins of the clock adapter into CLOCK, GND and VDD_XO on the BIII PCB. That’s all. The assembly looks pretty nice. With U.FL cable connected to the external clock from FIFO clock board and onboard XO removed from the socket, ESS9018 works at SYNC mode; while with on board 100MHz CCHD950 plugged into the socket and external U.FL clock cable disconnected, it works at ASYNC mode. So, having this small BIII clock adapter, it will be very easy to switch between ASYNC and SYNC mode. So, different modes with different clocks will be experienced and a lot of researching and comparing are waiting. Please see the pictures below for the configuration and details. Please note the name of pictures for the meanings.
#746 | |
Ian
#747 |
now you just need ackodac and forget adapters
it was interesting to hear it confirmed your simple experiment showing unlocks every ~10mins before adapter and no unlocks after, very simple demonstration. your adapter is great, brings this signal integrity to those with BIII..almost
#748 |
I hope so, as well as the D1 IV
#749 |
indeed, it surely must be in production now. i'm looking forward to drawing a line under the dac project for a while after I build the second D1 and focus on speakers
#750 |
Ian.
Why don't you built a DAC by yourself? Instead of tweaking an average 3rd party product you should built your own DAC. It's just a PIC and a DAC on top of your stuff. Shouldn't be such a big problem for you.
::: Squeezebox Touch Toolbox and more ::: by soundcheck |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1798 | Yesterday 08:44 PM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1306 | 9th June 2013 10:09 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
