Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter - Page 68 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th June 2012, 04:40 PM   #671
Originally Posted by iancanada View Post
I don't see any problem if you keep TTL low for no-selected signals, except the souce ground is too noisy. But the FIFO board doesn't have a spdif input, you have to feed it into the ttl input of the spdif board.
Ian
Thanks Ian, I mean the TTL input and source selection of the SPDIF broad. Sorry for the confusion.
Old 17th June 2012, 08:27 PM   #672
Default Another route?
Originally Posted by Blitz View Post
one question...what is the best practise to get i2s from the pc ? usb or directly fro, the sound card like a julia ? or other method ?
Originally Posted by qusp View Post
USB, unless you can mount the juli@ right next to the dac somehow. using i2s over distances to connect boxes is nothing but hype, its not designed for long connections and anything that makes it able to adds jitter
*SNIP* Different from S/PDIF, I2S is not an isolated transmiting, which obviously introducing EMI noise via ground or ground loop. Another problem is, TTL was not designed for distance transmiting. So, for I2S applications, I'm highly recommending using logic isolate chips, and making the cables as short as possible(or converting them into LVDS).
Is there anybody has ever tried NVE IL7XX digital isolators or other digital isolating solutions for I2S signals? *SNIP*
This conversation is getting very interesting to me. I use a modified Juli@ on a music server based on the cMP/cPlay by cics. I'm currently feeding the I2S from the Juli@ to one of the ES9022 DAC cards from DIYAudio's EUVL… very nice sound. The ES9022 card is mounted directly on the Juli@'s digital section with very short I2S connections(shorter than the stock card's connections to its stock DAC).
But I've got a Buffalo-II I'd like to install and with the various output stage & power supply options, it's a challenge to package into the PC's case. Also, I'm sure that getting it outside of the case will get it into a lower RF/EMI environment, even with all the work I've done to lower that inside of the case (extreme SW minimization plus all linear supplies to the Mobo, next up is removing the chips for un-needed peripherals on the Mobo!).
My current plan is to use an LVDS transmitter-receiver pair (I currently have the Twisted Pear Teleporter) to lengthen the I2S connection to 2' or so to that remote DAC. I know that PS Audio's scheme to transmit these signals via LVDS over an HDMI cable seems to be sucessful… not only for them, but also K&K Audio, Wired4Sound, Sonore, Chiaki/Bunpei's MicroSD card player, & Fidelix among others. I don't know about all of them, but I do know that PS Audio, K&K, & Chiaki/Bunpei do an asynchronous reclock at the receive end (& Chiaki/Bunpei also can supply HW to do a synchronous reclock which they have said is better-sounding). Twisted Pear also seems to be very happy with how the Teleporter works for them.
That's where the Asych I2S FIFO comes in. I got one from the tail end of the first GB. My plan to set it up as follows: cMP/cPlay PC -> Modified Juli@ -> TP Teleporter transmitter -> CAT6 -> TP Teleporter receiver -> Ian's Asynch I2S FIFO w/dual clock board (setup synchronous with the DAC) -> BuffII -> output stage (current top picks are TP's Legato, OPC's D1, & EUVL's Sen).
I know that the LVDS does add some jitter… theoretically less than an isolator like the NVE IL7XX. And according to who you ask, the LVDS seems to impart some amount of isolation (but Fidelix & K&K still have galvanic isolation at their receive end). Hopefully the Asynch I2S FIFO will minimize the impact of this added jitter, but I'm guessing that you still want to keep the jitter as low as possible, which is why I'm not currently planning to add NVE IL7XX or other isolators into the stream.
Why all this instead of the Asynch USB everyone else is going with? With the latest refinements of the cMP/cPlay setup, one lays into Windows XP with a machete and cuts out EVERYTHING not needed for basic playback (resulting in a OpSys + player of under 15Mb!). For those using a PCI-connected sound card like the Juli@, this includes fully disabling the USB functionality, both in the Mobo's BIOS & in WinXP. To us practitioners, this does appear to make a significant sonic difference (no trolling on this please… if you must, start another thread). Plus I have an investment in making the Juli@ digital section work well (with very good sonic results so far). And also, because not a lot of people are doing it this way (gotta be an individual, right?)
My question is, does this sound like a plan? Or have I missed something terribly important?
Greg in Mississippi
P.S. for those getting up to speed on this, here's some useful links:
EXAU21 (uses NVE IL7XX GMR Isolators & has been connected via the Fidelix LVDS interface…. Worth searching through the thread for these & jitter discussions): exaU2I - Multi-Channel Asynchronous USB to I2S Interface
XMOS USB->I2S (also uses GMR Isolators & worth searching through): http://www.diyaudio.com/forums/digit...interface.html
TP Teleporter LVDS Jitter: Introducing the bit "Teleporter"
Chiaki/Bunpei's MicroSD Player & Fidelix's LVDS / IL7XX setup: MicroSD Memory Card Transport Project
Search the K&K Audio forum on the Audio Asylum for info on their I2S-connecting LVDS Setup (too many useful threads to post here)
GLT's experiment with a GMR isolator on I2S: Experiments with NVE IL715 Isolator H i F i D U I N O
Info on Juli@ card mods: Audio Asylum Thread Printer & Audio Asylum Thread Printer
Everything matters!
Old 17th June 2012, 08:36 PM   #673
qusp is offline qusp  Australia
qusp's Avatar
i'm aware of all that reading material, seems a massively long way around to me, I gather the juli@ isnt capable of super high speed, nor multichannel, so I dont see any benefit over just using spdif into the fifo, as mclk is decoupled and the rest is buffered and reclocked
theres a different rulebook with this device. going to great lengths to use i2s when you arent using speeds higher than spdif can do doesnt make a lot of sense IMO. want isolation? use toslink. since you have it already sure I guess so, but I wouldnt bother if you havent bought everything. all of your psu tweaks and messing around with the mobo may have been quite meaningful before, but since none of the error sources you are decoupling are passed through the fifo..well =) or didnt you get the spdif input board?
of course this should be equally so for the i2s and teleporter, any jitter should be wiped out, but is it worth the trouble? I would have thought the fifo in the signal was individual enough, too much else becomes bad engineering, well past overkill IMO
Old 17th June 2012, 08:56 PM   #674
qusp's Avatar
ahh but i2s comes with ground if you are going directly in. hmm so really its clean ground on the i2s, or just use spdif.
Old 17th June 2012, 09:28 PM   #675
iancanada's Avatar
Greg in Mississippi
Your project sounds great!
If it is possible, using the logic isolation receiver like IL7XX for a PC based hifi application. That amount of additive jitter is not a big deal. FIFO could tolerance with them without any problem if you don't have anything wrong with the data.
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 17th June 2012, 09:33 PM   #676
Qusp,
I knew you were aware of most of these links seeing that you were a contributor in most of the DIYAudio ones (dude, I follow your posts… If I want to know what's the hottest tech in the DIY audio world, I look to see where you are posting!). And I figure that IanCanada knows most of these too… I just didn't expect everyone who'd respond to or be interested in this would have seen all of them.
Then as far as applicabiity, I'm not looking for anything above 192 & stereo with standard WAV/FLAC files. I know you're into multichannel & high-rate, but I'm pretty old-school.
As far why I'm going to these lengths, to start I'm doubly berift of SPDIF… I not only didn't get Ian's SPDIF card, but also remove the SPDIF capability in my modifications to the Juli@. Luckily, the two TP Teleporter modules didn't cost me any more than Ian's SPDIF card.
Second, several manufacturers who I trust (PS Audio & K&K) seem to suggest that the I2S via LVDS is a good idea. 100,000 flies and all that.
Third, I have an aversion to adding data format conversions. I know Ian's SPDIF board with his reclocker fixes this, but I still would prefer to keep the signal in the I2S domain once it's there as long as I can use it without badly corrupting it. The LVDS transmission seems to do a pretty good job of this.
And finally, I'm not convinced that even with a device like Ian's Asynch Reclocker that the source doesn't matter. After getting this all setup, I will try different computer source setups & unmodified Juli@ to see if there is an audible difference. Hopefully there won't be and I can use a less 'hair-shirt' player setup than the severely lobotomized cMP/cPlay setup I currently use. But I'm still a bit skeptical on this.
Of course, all of this is philosophy and un-provable. Sorry I don't have any good data to back this up!
Later!
Greg in Mississippi
P.S.
My understanding of the LVDS connection is that the differential pair provides a connection that doesn't require a ground connection between the sender and receiver and that the I2S ground at the receiving side is the local ground (hopefully cleaner). Please, if I'm not understanding this right, help me do so.
Everything matters!
Old 17th June 2012, 10:18 PM   #677
Ian
Thanks Ian.
I'd already considered adding a GMR isolator and have even gone as far as getting the devices on-hand.
So it will likely be an alternative I try after the initial implementation.
Does it make more sense to put it at the sending or receiving end? I'm inclined to do it at the sending end before the LVDS & power it via a power supply that is separate from the computer supplies.
TIA for your answer... and really, really, thanks for providing this great device to the DIY'er.
Greg in Mississippi
Everything matters!
Old 18th June 2012, 03:28 AM   #678
iancanada's Avatar
Thanks Ian.
Greg in Mississippi
You welcome, Greg.
Ian
Old 18th June 2012, 06:31 AM   #679
qusp's Avatar
Qusp,
... stalker ha... nah i'm just a bit more ermm..vocal about it than most. there are people like Ian tinkering away that put me and my efforts to shame. though perhaps as i'm very much hunter-gatherer I may cover a more diverse range of technologies than someone with the head-down creation mode going on.
One of these days I might actually get creative, but for now i'm happy to just let those who really know what they are doing do their thing.
all good then, well yeah if you hadnt already started down this road I would just be saying forget it, go with the fifo spdif, but since you are most of the way down this road your solution seems sound; a bit convoluted and theres a bit of redundancy, but sound.
yeah they are neat little units, I guess i'm just not totally sold on RJ45, the HDMI connector is much better suited. this may not have any basis in reality of course.
absolutely its a good idea if you must have i2s over any distance, but it doesnt beat just having the thing close, i'm not convinced of converting to i2s so early in the signal path, I think usb with its full error correction and buffering is a more natural solution. I know its all rather topical/fashionable, but it seems counter-intuitive to me.
the spdif suggestion was instead of, not on top of your i2s transport, making for less conversions not more. we only suggested going back to spdif on the previous pages to solve the problem of needing multiple inputs
I understand the skepticism, but this is more than a reclocker, in fact the input clock bares no relation to the output clock, if I wasnt working on multichannel I would probably just go back to bnc or toslink on Ians spdif board and draw a line under it.
haha all good, if we had to do that any time we made plans, many things wouldnt get done
that was my point, I was just going through that in my mind, that direct i2s without isolation would be counter productive, so your LVDS or Spdif are needed if you dont have a clean ground. convoluted or not thats what youve got to do
Old 18th June 2012, 11:07 PM   #680
iancanada's Avatar
Default The real speed of Toslink optic transmitter/receiver working together with DIX9211
the optical input isnt limited to 96khz, your optical output is, haha I just noticed there is no tx on the input (i've only used optical or i2s) so ya I get your point.
I like I2S, it could go higher Fs and more than 24bit word length, as well as no need doing bi-phase encode and decode. Especially the USB, it’s kind of tendency of HD music output devide, I use it for most of the time.
But I still couldn’t help doing some research on the optical s/pdif to see what the speed limitation is.
I use a pair of TOTX147 and TORX147 on my S/PDIF interface board as the optic transmitter and receiver. The max rated speed was 15Mb/s. I don’t know what the testing condition was.
Using a 5 feet normal optic cable, I did a loop testing with a 192 KHz/24bit digital audio signal on my DIX9211 S/PDIF interface board. The testing last two hours, within that time, I didn’t catch any bit error. It was kind of bit-perfect transmitting.
However, by comparing, I did same loop testing under same condition on a couple of other DIT and DIR chips. The results were not as good as DIX9211. Some of them couldn’t lock stably at 192 KHz even with coaxial cable connected (I’m sorry I don’t want to tell what the P/N it was)
After that, I try to increase the Fs to 384KHz, none of them can get locked, of course they couldn't! J
So, I suspect, the real maximum Fs speed of an optical s/pdif is partly connected to the performance and ability DIX chip and not 100% limited to the rated speed of that opt transmitter/receiver, especially for a FIFO based application, which is not care much about the jitter from the input clock.
Just a sharing of my research experience with you guys for reference. J
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3024 19th February 2017 10:14 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1373 13th January 2017 06:45 AM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 01:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 10:22 AM
Copyright 1999-2017 diyAudio
