| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#531 | |
#532 |
That's right I'm doing the same ie: one BIB at 5,25 V and in excess of 0,5A to power the BIII and tridents.
The resistor gets hot but a small heatsink takes care of the transistors. ![]() The final product with independent digital PSU and analog PSU is another matter as the digital module has 4 BIBs for the BIII, FIFO, USB-I2S module and accessories so it should get a little hotter. I redesigned the BIB PCB for this case so i could make the thing more compact...we will see if it's feasible, here is a peak.. Last edited by CeeVee; 16th May 2012 at 11:08 AM. |
#533 |
is choosing a less facetious title...
hmm, seems to me certain elements of the BIII and fifo are analogue... the master XO board from the fifo, the 9018's DVDD L/R and AVCC L/R pins are analogue mechanisms and should be treated as such IMO. the model is looking good though, I see you are taking cues from the firstwatt heatsinks? nice
#534 | |
Your case look like a UPS
#535 |
is it really worth powering the fifo with shunt regs? I can understand powering the flipflops and clocks with their own dedicated shunts directly, but powering the whole thing with shunts when all the consumers on the fifo board have dedicated IC regs seems like creating a lot of heat for not much benefit.
#536 | |
. I'm gonna add more heatsinks and make them facing up. Hopefully I can get the stable temp around 50C.
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#537 | |
#538 | |
Probably right thanks for the head's up. |
#539 |
cool, well the sinks look nice enough though, I do like that angled fins look.
do what suits, but yeah I think I would either just use batteries and be done wit it, a basic but quality linear supply, or all out and supply the main board with linear and selected parts with shunts directly. powering the whole board is a bit of current and most of the benefits of shunt regs dont really apply when there is other regs in the way. the low impedance and high bandwidth makes little or no difference and sense/force lines dont have access to the loads. of course do what sounds good to you, but the heat created by a 500-600ma shunt is not insignificant, I would want to make that count. |
#540 | |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1304 | Yesterday 03:43 PM |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1724 | 22nd May 2013 06:50 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
