Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 7th November 2017, 06:58 PM   #4511
nielsek is offline nielsek
Thanks Ian for great products.
I hope itís the right thread to ask for help with my McFIFO and McDualXO. Until recently, Iíve been using them successfully with Curryman DAC (ES9023). Now McFIFO cant get a lock and McDualXO D1/D2 LEDís keep flashing when playing audio. No sound comes out. I measured voltages and on board XO REG (U13) OUT voltage is only 1.15v. I believe it should be 3.3v, what should I do next?
Old 7th November 2017, 09:29 PM   #4512
iancanada is offline iancanada  Canada
iancanada's Avatar
Hi ,
No worry.
1. Measure output voltage of U13 with both XO1 and XO2 removed;
2. If it is still low, measure the input voltage of U13.
Ian
Old 8th November 2017, 05:02 AM   #4513
Thanks Ian for prompt feedback. Here are the U13 IN & OUT with different power sources and clocks:
Code:
reg clocks + fifo power (J18)	5,08	1,17
NO clocks + fifo power (J18)	5,16	1,19
NO clocks + SilentSwitcher 	5,47	1,22
reg clocks + SilentSwitcher 	5,53	1,23
CCHD-957 + SilentSwitcher	5,56	1,24
Anything we can conclude from this?
Originally Posted by iancanada View Post
Hi ,
No worry.
Ian
Old 9th November 2017, 11:56 PM   #4514
canvas is offline canvas  Taiwan
Without the XO (and power-off), you can measure the resistance of v-out and ground to see if they are shorted.
FS: BUF03,OPA627,AD797,AD844,LT1028... Here
Old 10th November 2017, 04:58 AM   #4515
Thanks. I measured the reading between GND and OUT on XO LDO REG (U13), with and w/o XO's installed. There was no reading, so shouldn't be short.
What next should I check?
Old 10th November 2017, 11:22 AM   #4516
Have you ever reversed the v-in polarity accidentally? I once damaged the lt3042 due to incorrect input polarity.
Old 10th November 2017, 03:05 PM   #4517
Definitely not lately as haven't changed anything on McDualXO DC input. Can't confirm if ever. Any easy way to check it, without breaking off the LDO and replacing it?
Old 11th November 2017, 06:40 PM   #4518
MeiT is offline MeiT  Germany
Danke
Old 12th November 2017, 11:29 PM   #4519
If there is no short on the output, I'm afraid you have a faulty regulator on board. The power section of XO is quite simple and straight forward.
Old 14th November 2017, 11:40 AM   #4520
Henderson is offline Henderson
Banned
WHat is the Bclk speed at the output of the IanCanada Clock board with normal speed and the PCM board with full speed (not halfed) please ?
For a 44.1/16 material is it 44.1 K Hz x 16 (bits) x 2 (stereo channels) : 1.4112 M Hz ???
Need it to choose a divider for DEM feeding on a TDA1541A dac !
help much appreciated,
regards
H.
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
