| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#431 |
Hi Ian, very good. I'll look into these pictures, but not yet.
My nice will be here today and i have to help her solder a kit....a roboter kit. DIYRobot.... As for new functions of the fifo, are they reprogrammable in circuit?
If you can't trust your ears, then CLICK HERE |
#432 | |
Enjoy your weekend.
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#433 | |
Hi Ian,
Impressive progress. I reviewed your description (2 to 6) and the waveforms and everything looks good to me: - I like that you added 16bit support - The naming is clear like that (at least for me) - Simulation waveforms looks good - Leading clock selectable - too many goodies ![]() Quote:
How did you think it would work? - I2S in and selectable I2S out or Left Justified Out or - selectable I2S in - I2S out or Left Justified in - Left Justified out Thanks and enjoy your weekend (what is left), Zsolt |
#434 | ||
Hi Ian!
Oh, and for the different waveforms, they look good. I agree with about everything Zsolt has already stated. Nice there is 16bit also, who knows.... Anyway, hope you had a good weekend! Ciao, Tino
#435 | |
(CDROM, VSLI Solution audio chips)
www.hifiduino.wordpress.com |
#436 | |
I remember you need a rigtht-justfied input tapping from a CDROM? 16bit of 24bit?
#437 |
Hi Ian,
The vlsi audio chip (http://www.vlsi.fi/en/products/vs1053.html) are 32*fs I2S. The cdroms are 32*fs. Last I experimented with a TI ASRC, it required setting it as right justified. I'll have to get myself a logic analyzer to make sure. But DACs support I2S, RJ, LJ so having these options, plus 32*fs, 48*fs and 64*fs clock will make it a "universal" device
#438 | |
Good point glt, but the right justified is kind of word length related, usually it's 16 and 24 bit. Is that works for you?
#439 |
is choosing a less facetious title...
building up 'breadboard' for testing different options, clocks, references, regs IV etc for the dac that will drive my tweeters, the woofers are already covered with the NTD1 with another ackodac. some progress below, should power it all up tonight or tomorrow. I will try running Titan through the fifo as well as direct. it has its own clock fanout buffer and smaller fifo afaik and some rather nice clocks, so should be an interesting comparison, titan is capable of higher bandwidth than the fifo is in its current state, so i'll stick to 192 or below for the tests. the platform is normally mounted above the IV with the NTD1 thus the fairly useless set up here, though it will provide another layer of space for batteries, references etc for the rest of the testing
yes the 4 channel dac will be a 2 box affair with transformers and preregulators, battery charge circuit, along with some control circuitry in one case and the rest, DC onwards, dacs, input circuitry and output stages in the other. its a pretty crazy build even for these 2 channels, first up i'm driving the wire BAL-BAL headphone amp directly and have altered the input circuit slightly to allow current mode coupling please excuse the messy bench and rough and ready layout, i'll be switching things in and out so its only temporary and no thats not earwax on the cotton buds, its cardas rosin flux everything is currently floating in this build too, so thats another thing i'll be optimizing with this, the analogue stages including those in the dac should have a common ground reference, but the rest can float really as its either batteries, or a dedicated secondary winding for every consumer, so we'll see. the regs on the ackodac are all choke input so they float toodacs arent what they used to be hey? ha Last edited by qusp; 24th April 2012 at 10:59 AM. |
#440 |
to clarify, the ground plane is segmented, not all regs have a dedicated segment so I guess pairs of left/right are floating together. missed the edit to add this above, sorry
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1715 | Today 08:15 AM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
