Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th March 2012, 05:24 AM   #301
Originally Posted by iancanada View Post
Hi coolhead,
The total power consumtion is up to what oscillators you are using. For the default configuration, the total current is around 110mA for all the 3 boards.
Have a nice weekend.
Got it.
Thanks.
Old 19th March 2012, 12:07 AM   #302
iancanada's Avatar
Originally Posted by UnixMan View Post
you may consider integrating the USB interface from this project: "Open-source USB interface: Audio Widget"
Sounds good. Maybe I need buy one of that kit and trying to figure out how to integrate with my fifo.
Thanks,
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 19th March 2012, 07:58 AM   #303
zinsula is offline zinsula  Switzerland
zinsula's Avatar
As the async USB is kind of "decoupled" from the source, there should be no need to pass the data though anoter FIFO.
But with the dual clock board, some nice thing could be done perhaps.
If you can't trust your ears, then CLICK HERE
Old 20th March 2012, 04:44 PM   #304
glt is offline glt  United States
Hi Ian,
In post 54 you said:
"6. Output the MCLK and I2S signals directly without passing through FIFO;"
What does this mean?
www.hifiduino.wordpress.com
Old 20th March 2012, 07:41 PM   #305
Also, no Potato Semi flip-flop in the shipping versions of the board?
Old 21st March 2012, 01:08 AM   #306
iancanada's Avatar
Originally Posted by glt View Post
Hi Ian,
That means MCLK and I2S signals are output from clock board finially, not directly output form FPGA/CPLD which usually comes with much more jitter.
Old 21st March 2012, 02:12 AM   #307
iancanada's Avatar
Hi glt,
I gave Ghz flip-flop a try on my dual clock boare prototype version 2.0. However, since prototype V3.0, I switched to 3 NXP PicoGate flip-flops. You may find them from pictures on my previous post since
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter P17, as well as from the pictures on the GB thread
Both 600Mhz Potato flip-flop and 550Mhz PicoGate flip-flops sounds great. They did perfect job on re-clocking. The only reason was Potato is a very small company, sourcing from a big company make me feel better on quality control because of my long time medical grade design experience.
I still have a couple of prototype 2.0 empty pcb. I can give you one of them for free if you want to try it again by yourself.
Have a good night.
Old 21st March 2012, 04:31 AM   #308
Hi Ian, thanks for the clarification. The only reason I ask is because I started reading the thread with more attention and then went over the literature over at Potato Semi and got all excited about the technology. Then I went to look for the chip on the clock board and I didn't find it. :-)
I don't think I'll take your offer for a PCB because I can't solder at that fine scale. I'll ruin the board.
In any case, I put up some pictures over at my blog. Let me know if what I said is accurate.
Old 27th March 2012, 05:39 PM   #309
mfr is offline mfr  Canada
mfr's Avatar
Default Any kits left?
Hello,
I was not following the thread for a while. If for some reason there would be more kits, I'd have one of each boards.
Thanks,
MF
Old 27th March 2012, 11:16 PM   #310
gvelim is offline gvelim  United Kingdom
FYI
Interesting startup in the oscillator market Accusilicon, we make ultra-low phase noise XO/VCXO/TCXO ICs
their XO clocks product reported as
12KHz-20MHz RMS jitter: <50fs (122.88MHz)
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1714 11th May 2013 03:43 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1303 10th May 2013 05:19 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Page generated in 0.55822 seconds (100.00% PHP - 0% MySQL) with 10 queries
Copyright ©1999-2013 diyAudio
