Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 26th August 2013, 10:49 PM   #2971
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by mcluxun View Post
It's more likely to be a computer outputting i2s through onboard sound card.
The rpi is running a linux system with modified kernel.
It's more than a sd card player. I installed a hqplayer network adapter on it (for serious listening). So it could be controller remotely and headless from other computers.
Also I have squeezelite/squeezeslave running on it, so it could be a full function squeeze network player.
It can run airplay and mplayer as well.
I put some epoxy around the backdoor kit so it's less scary.
Im more of a computer science guy who just picked the solder iron I'd like to help out if you got any software problem with it.
Thanks mcluxun,
You did good job on soldering the backdoor connector .
I'm interested in buying a RPI, will let you know if I have any question then.
Ian
Old 26th August 2013, 11:26 PM   #2972
iancanada's Avatar
Default 90.3168MHz/98.3040MHz OCXO to test, -135dBc/Hz@100Hz
A friend of mine sent email to me a couple of months ago, he told me that he got problem when playing 90.3168/98.3040 MHz clock on my Dual XO clock board and FIFO KIT. I replied, yes of course, Dual XO clock board does not support 90.xxx/98.xxx MHz XO so far. Then the guy sent another email to me and asked if there is any possible revising the hardware/software somehow to make it working for those frequencies, because they are really nice clocks. He said he would send them to me for evaluation during R&D time if there is any chance to make it.
I was quite exciting when I received them, they are a pair of 90.316800/98.304000 MHz OCXO. Phase noise only -105dBc@10Hz, -135dBc@100Hz. It seems they are exactly what I have been looking for for years. According to the specifications, the phase noise performance would be much better than the Si570, as well as CCHD951.
I thought OCXO could be very hard to use because of the high power consumption of the oven. But it seems I was wrong, this OCXO is different, only 150mA at start up and turns to 50mA after two minutes. It would be suitable for the DUAL XO clock board and my ESS9018 DAC. LifePO4 battery cell would be good choice to power it. But I have to revise the Dual XO clock board hardware, and probably firmware, to make it running at quad speed mode to support 90.3168/98.3040 MHz XOs.
The guy didn’t tell me where he got them and how much they are. Also, there was no any manufacture information on the spec he gave to me. I think he just wants to keep that information as secret for now for some reason.
I couldn't wait to test them. Will it be another planet or just no big difference?
Ian
Old 27th August 2013, 11:34 AM   #2973
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
Ian
Ian, are these OCXO's from this supplier:
http://www.diyaudio.com/forums/vendo...ml#post3586014
That is very low phase noise for a ~100MHz oscillator, especially close to
carrier. Generally speaking 5 to 10MHz is optimum for low phase noise and
the further you get away (higher) the phase noise, especially close in
suffers.
Bear in mind when comparing a 10MHz XO to 100MHz, you have to allow
for 20dB poorer phase noise of 100 due to shorter period for same jitter.
They might be SC-cut crystals by the look of the cans, if this is the
case they will be -very- expensive.
One other way to get very good close in phase noise with 100MHz OCXO's is
the use of frequency multiplier and also phase locking using low freq
oscillator as the ref. The tradeoff is usually poorer noise floor.
I am sure you will get a lot of interest in these
Get them in and cooking! Tell us what you think.
I am currently using SC-cut 11.2896MHz OCXO's for DAC's that have
-120dBC / 10Hz offset from carrier. However I am finding there is a lot of
subjective difference with various topologies of PS, squaring circuit, even the
OP loading makes significant difference to sound.
So there appears more to it than just a nice phase noise plot.
Z
Old 27th August 2013, 03:54 PM   #2974
qusp is offline qusp  Australia
qusp's Avatar
they look very nice, but i'm going to stick my fingers in my ears
la la la la la la
Old 27th August 2013, 10:38 PM   #2975
iancanada's Avatar
suffers.
Z
Thanks zenelectro for the link and the info. I think that's exactly what it is. But the price is totally out of my expectation, it's too much expensive than Si570 or CCHD957. I don't know that is reasonable for an OCXO or it's not worth it.
I did some search on digikey and found many OCXO's with similar performance are not as expensive as this one. Such as:
http://www.abracon.com/Precisiontiming/AOCJY.pdf
http://www.conwin.com/datasheets/cx/cx207.pdf
The only thing it that there was nothing with audio frequencies. However if going with ESS9018 internal clock, 100MHz SC-cut OCXO would be a good choice.
Any way, I'll going real listening test with these 90.xxx/98.xxx OCXOs to see what's gonna be happened.
Thank again
Ian
Old 28th August 2013, 12:20 AM   #2976
1audio is offline 1audio  United States
They look a lot like some parts I found at a Russian OXCO vendor ?Magic Xtal Ltd.? develops and fabricates all kind advanced Oven Control Crystal Oscillators (OCXOs). Portfolio of the company contains ultra-miniature vacuum sealed OCXOs with 1.5 cm3 volume and 150 mW power consumption, high-frequency low phase The specs are similar. However I was quoted around $110 ea in quantities of 10.
The datasheet looks similar as well http://magicxtal.com/upload/iblock/040/MXO37-8D-14D.pdf
They are probably a piece of the Russian Military Industrial Complex looking for some real income. . . However the NSA will be watching.
Demian Martin
Product Design Services
Old 28th August 2013, 12:23 AM   #2977
hochopeper is offline hochopeper  Australia
la la la la la la
HAHAHAHAHAHA. Mate, when I read Ian's post the first thing in my mind was how will qusp's jitter-audio-nervosa handle seeing these!
Me, I wish I had the tools in the lab (read - garage) where I could measure some of these changes myself then play around with some variations. I want to know what performance I'm getting in-situ. Slowly getting there.
Zenelectro, have you done any measurements looking at changes of PSU, squaring etc? you've been at this clock biz for longer than I have ...
Ian, we're all very jealous and look forward to reading your impressions!
Old 28th August 2013, 02:15 AM   #2978
iancanada's Avatar
I found this one:
CTS Valpey Corporation
http://www.ctsvalpey.com/Collateral/...odel%20144.pdf
I don't know it's the same guy or not
Old 29th August 2013, 04:38 AM   #2979
I would not be surprised of they were the Russian parts rebranded. The specs are virtually identical.
Demian Martin
Old 29th August 2013, 08:46 PM   #2980
ULNOCXO is offline ULNOCXO  Europe
Dear diyAudio Jitter Fighters,
my name is Mauro Gavinelli and I am a member of the ULNOCXO team.
I followed your very interesting discussion initiated by iancanada with the post #2972 on this thread and I see that you need some more information to better understand what is in iancanada hands and what we are proposing, so I try to resume the whole story.
We are few friends sharing a passion for the top level audio and we like to experiment seeking for a (quasi) absolute sound.
We tested the iancanada products and we appreciated them so much that we wanted to listen them with the lowest jitter clocks available at an affordable price; when we came to look to the market we contacted many OCXO dealers and discovered that no one had an off-the-shelf component with all the characteristics needed to be fitted directly on the board.
We started to look for someone capable to produce such custom component and found only one european dealer (we are located in EC area - Italy) that gave us a positive answer.
The price of the ULNOCXO samples was quite high, but we decided to go on and the sound we listened was a real quantum leap.
The test was not easy due to the fact that the iancanada products (basically the current Dual XO board) was designed when the 90.316800 and 98.304000 MHz clocks were not yet available and the power supply should have been improved in order to guarantee a such low phase noise, but still in that conditions the quality appeared so high that we decided to contact iancanada in order to try to adapt the Dual XO board to these frequencies.
We understood that this couldn't be a quick process due to the above mentioned problems he had to overcome, so, while we were waiting a feedback from iancanada (that came with the a.m. post), we evaluated with our provider the possibility to share this great listening experience transforming a couple of samples in a real product.
They have been expressly designed on our specification, tailor made for Audio applications, so we posted the ULNOCXO thread to know if there is an interest for an OCXO with this high performances.
From here on the story is in this thread.
I read with great interest the discussion and see that all the evaluations are correct, I would like just to put in evidence a couple of points that in my opinion are not enough highlighted.
- Comparison with of the shelf items:
in the thread are mentioned many OCXOs with apperently similar phase noise but often the data sheet values refers to the 10 MHz version while the two ULNOCXO samples runs very near to 100 MHz. zenelectro is right when he says in his post #2973 that 10 MHz have a 20 dB advantage vs. the 100 MHz versions (I say even 25dB) so a comparison can be made only between the TEST data of our two ULNOCXO samples and the 100 MHz datasheet values (Magic and CTS)
The ULNOCXO samples appears to have lower phase noise.
- Power consumption:
Steady state: the two ULNOCXO samples requires 165 mW while the other comparable OCXOs requires 200 or 250 mW
Warmup: the two ULNOCXO samples requires 627 mW while the other comparable OCXOs requires 1000 or 1100 mW
- Control Voltage:
It is our opinion that for audio quality a low phase noise is much more important than a precise frequency so per our mandatory request the Frequency Control Voltage function has not been implemented lowering further the phase noise.
- The ULNOCXO samples are a Magic rebrand:
well, obviously we wasn't and won't be told by our provider, maybe they are! But comparing the measured phase noise of the ULNOCXO samples with the best Magic datasheets data (MXO37H/14) the maximum ULNOCXO samples figures (the only one guaranted values by the producer) are better then the Magic minimum figures. If they are a rebrand for sure they are special series.
- Price:
as told above we are located in Italy and the only way to sell something that is not a second hand item is to operate by means of a company and this has a certain cost; we are still working to find solutions to reduce the price of these new OCXOs, but consider that looking deeply to the performances they are really exceptional and also our procurement cost can't be reasonably low.
1audio: with reference to your post #2976, which Magic product are you referring to for that price, in term of frequency and phase noise figures?
For your convenience I report here the measured phase noise of the ULNOCXO samples(dBc/Hz):
90.316800 MHz : -65(@1Hz) -100(@10Hz) -130(@100Hz) -159(@1kHz) -168(@10kHz) -170(@100kHz)
98.304000 MHz : -67(@1Hz) -101(@10Hz) -131(@100Hz) -159(@1kHz) -168(@10kHz) -170(@100kHz)
We are glad that iancanada could spend a word on these ULNOCXO samples and we hope he can test them at best, possibly upgrading his board, in order to know his opinion not only on the base of datasheet numbers, but mainly on his listening experience; yes it's a subjective experience, but in the end it is the one that really cares us, audio lovers.
Mauro
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
