Go Back   Home > Forums > Source & Line > Digital Line Level
Old 28th February 2012, 02:17 PM   #281
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
nope, Tom would be much more obvious if he was flaming me, he just happens to spend his days creating proofs with strings. of course now he mentions it ive seen/read this many times, but had math text/brain fail and dont mind admitting it when i do, doesnt make me feel stupid
and wow who woulda thunk it, 2 people among ~20million collide across teh interwebz...amazin.....
Old 28th February 2012, 11:54 PM   #282
iancanada's Avatar
Originally Posted by zinsula View Post
Thank you Ian. This could well be an option, but if using an external clock, the "comfortable" automatic clock switching is lost.
Primarily, I'd plan to connect the FIFO to a multi format DVD player, which puts out both the 44.1 and the 48kHz - Family of sample rates.
But I'll take one...
Hi zinsula,
Design a clock board for my fifo with automatically Fs switching function is easy. As I mentioned before, the fifo board is working at slave mode, the clock board is the master. The default MCK is 256Fs, so just desigen a clock board, output 11.2896MHz if I2S is 44.1K and 12.2880Mhz if I2S is 48K(your clock board should know which Fs it is). Anything else will be dealt with at background by fifo fpga/cpld. If MCK frequency is not match the I2S, the output of the fifo will be silenced automatically until right frequency is being fed. Just hope it works for your idea.
Good luck zinsula,
Ian
Old 29th February 2012, 06:25 AM   #283
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Thanks Ian. As I am at a remarkable loss when it comes to program something, I would have some troubles to let the clock board know which clock it has to select. So I'm playing safe and ordered the dual clock board too.....
If you can't trust your ears, then CLICK HERE
Old 29th February 2012, 06:38 AM   #284
qusp's Avatar
the regulator circuits on the board are actually pretty trick, particularly given the high quality HPF and LPF through the use of newish 4 pole capacitor/inductor networks
Old 29th February 2012, 11:38 AM   #285
So very true
I do enjoy proofs involving strings!
Old 29th February 2012, 11:51 AM   #286
qusp's Avatar
even typing that sounded clumsy
sneaky bastard...
Old 8th March 2012, 08:32 AM   #287
vzs is offline vzs  Europe
Lastly I will add my 18bit LSBJ converter board after the reclock kit and have some more questions before doing the pcb:
1. As the SCK output has to drive 11 gates on my converter board do I need a buffer like 74ACT125 or can the reclocked FIFO output source that many gates?
2. Can you tell me the Farnell code of the 7-pin PH 2.0mm connector + double-ended PH cable you are using as I couldn't find them.
3. I'm trying out the single clock board and plan to use it with 44.1KHz based stream. Can I use a 22.5792MHz clock (512*Fs) or do I have to stick with a 11.2896MHz one?
Thanks.
Zsolt
Old 8th March 2012, 11:53 PM   #288
iancanada's Avatar
Thanks.
Zsolt
Hi Zsolt,
1.The max output current of the I2S signals from the clock board is LVTTL +-20mA, but 11 gates are too much for keeping low jitter performance. Suggest useing low jitter dedicate clock fanout buffer driving them. The one on the Dual XO clock board is one of the good choice, only 18fs additive jitter. Don't let AD1865 share clock driver with other load.
2. 7PIN PH2.0 Digikey P/N
455-1739-1-ND SMT
455-1709-ND through hole
U.FL cable
H11555-ND
U.FL socket
H11891CT-ND
3. The default master clock of the FIFO is 256Fs except other setting by the external mcu. So if you using the single clock board, you have to stick with 11.2896MHz for 44.1K. Changing the default to 512Fs is easy, I can re-program it for you if you want before defivery so that you can use the 22.5792M clk. The only thing is I don't have enought time doing the test for that special version.
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 9th March 2012, 12:44 AM   #289
glt is offline glt  United States
Originally Posted by iancanada View Post
3. The default master clock of the FIFO is 256Fs except other setting by the external mcu. ...
Is there a s/w interface to the FPGA?
www.hifiduino.wordpress.com
Old 9th March 2012, 03:13 AM   #290
iancanada's Avatar
Yes, FIFO integrated a 32bit SPI.
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1724 Today 06:50 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1303 10th May 2013 05:19 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright ©1999-2013 diyAudio
