| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#271 | |
![]() Ian |
#272 |
Just a kindly reminder that the Ian asynchronous I2S and S/PDIF FIFO KIT group buy is running. Please go the group buy area for details: http://www.diyaudio.com/forums/group-buys/207438-ian-asynchronous-i2s-s-pdif-fifo-kit-group-buy.html I will continue this thread for technical issues, new progress may include: 1.Trying suitable low noise power supply for oscillators and FIFO project. 2.New Si570 based clock board. 3.I2S and S/PDIF FIFO applications. 4.Possible battery based power supply with charging management. 5.Technical supplort ……. Have a nice week. Ian
#273 |
is choosing a less facetious title...
looking out for that Si570
#274 |
Hi Ian, I'm still reluctant to buy the otherwise very impressive FIFO kit as I'm unsure about how easy it is to leave out the LDO and to power the clock(s) with a very low noise regulator.
- Do you supply a schematic with the kit? - Does the dual clock board have one LDO per clock? I see in your previous post that you are investigating a low noise power supply. Would that mean having it on (newly designed) boards or add on?
If you can't trust your ears, then CLICK HERE |
#275 |
Does someone enlighten me about the performance of the Si570 down to 10Hz offset and at clock rates we need in this project (i.e. around 25 MHz)?
I can find phase noise spec for clock frequencies above 100MHz and down to an offset of 100Hz. However those values are significantly less good than eg. the Crystek CCHD-957 Model or a Tentlabs clock at 100Hz offset and lower (i.e. suitable for this project) clock frequencies.
If you can't trust your ears, then CLICK HERE Last edited by zinsula; 27th February 2012 at 12:18 PM. |
#276 | |
The easiest way to evaluate and connect an external low noise power supply is using the IC socket as an adapter, just as what I did before to evaluate the battery power supply. http://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter-24.html After you making sure the external power supply is good enough, you can connect them to the dual XO board by just removing the filters or the LDOs. It’s not a difficult job, especially for you J. For a very skilled DIYer like you, what I recommended is configuring a FIFO with external clock, (please see the user guide for detailed) which is not suggested for the normal users. So that, you can design your own power supply and clock and do not have to be limited by my board. Although I couldn’t guarantee my clock board is the best, but it truly based on long time testing and optimizing. You could keep it as a reference, by comparing with it, you will know by how much your improvement is achieving. Once I have time, I’ll design a prototype PCB for Demian’s reg. I could send a couple of that PCB to you for free to make some evaluation if you like. Ian Last edited by iancanada; 27th February 2012 at 11:48 PM. |
#277 |
Thank you Ian. This could well be an option, but if using an external clock, the "comfortable" automatic clock switching is lost.
Primarily, I'd plan to connect the FIFO to a multi format DVD player, which puts out both the 44.1 and the 48kHz - Family of sample rates. But I'll take one...
If you can't trust your ears, then CLICK HERE Last edited by zinsula; 28th February 2012 at 05:57 AM. |
#278 |
it will be interesting to put Demians regulator up against Jung's AD797 based circuit from the old Electronic Design article from analogue devices 'how to build an ulra-low noise reference' which has noise estimated at 1.25nV/(2^root)Hz (not sure how to make the square root symbol with normal text)
#279 |
Most people will write sqrt(*).
#280 |
Egad! Intra-Oz flaming.
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1304 | 23rd May 2013 03:43 PM |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1724 | 22nd May 2013 06:50 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
