Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter - Page 276 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th May 2013, 12:40 PM   #2751
dvb projekt's Avatar
Originally Posted by iancanada View Post
If it is possible, try to monitor the battery voltage by a passive voltage meter to avoid any damage caused by over discharge.
I found a small and cool looking voltmeter HERE.
Great to integrate in a front panel.
What do you think...
Reference TDA1541A DAC project PCBs / Tube-I-zator PCB
Stock status in my Blog
Old 10th May 2013, 12:46 PM   #2752
Hi Ian
while still trying hard to understand your i570 protocol for the Arduino code, I am trying to verify the communication port of the i570 is working. I connected it to the RS232 port of my PC and use hyper-terminal to monitor its output but see nothing.
Could you advise the comment in ASCII for requesting the sampling frequency?
Old 10th May 2013, 01:35 PM   #2753
qusp is offline qusp  Australia
qusp's Avatar
not passive and fullscale is 200mV, so you will need to add something to accurately attenuate the voltage to feed to it. looks cool though ...
my god its expensive!
Old 10th May 2013, 01:41 PM   #2754
Originally Posted by bigpandahk View Post
Hi Ian
The protocol doesnt allow that.
The protocol send event data whenever the fifo has a change.
Change the fifo input while you read the serial port, compare what you receive with the information Ian has given. I don't think it is fair for Ian to be answering these questions.
Old 10th May 2013, 02:01 PM   #2755
When I connect the Arduino to the i570, the i570 doesn't select the correct clock for the BIII. Normally, the three LEDs for Fs shall be on when playing music. With the Arduino connected, only the 512 is ON. No lock on BIII.
If I connect it to the PC RS232 port, it keep on sending some data and all the LED for the MCLK flashing. Also no lock.
Thanks for your advise, I will try some other method to see if I can solve the problem.
Old 10th May 2013, 04:45 PM   #2756
iancanada's Avatar
Hi Ian
I am trying to read the sampling frequency from i570 and display it on GLCD. Is there any simple instruction to do it? I don't understand how to use your code.
Hi bigpandahk,
I would suggest you first trying to program your controller to listen to the message sent from Si570 clock board.
Once you get to know what its talking about, it will be very easy for you to figure out how to display and control it.
The protocol I gave was originally from Si570 driver source code, you can use them directly in your C/C++ code by removing the //
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 10th May 2013, 04:58 PM   #2757
Avro Arrow's Avatar
Default Battery Voltage Monitor
Simple Above/Below voltage monitor:
Old 10th May 2013, 10:49 PM   #2758
iancanada's Avatar
Yes, it looks cool. With a couple of hundreds K resistors and internal battery/power supply, I don't think it will introduce anything.
Ian
Old 10th May 2013, 10:51 PM   #2759
iancanada's Avatar
That's another nice solution. Very easy to implement. All components a passive, it's worth to give a try.
Ian
Old 10th May 2013, 11:31 PM   #2760
Hi bigpandahk,
Ian
Thanks Ian
That's what I've done. Will learn more from the WEB and try.
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3040 27th March 2017 03:45 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1375 4th March 2017 07:58 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright 1999-2017 diyAudio
