Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 2nd May 2013, 09:10 AM   #2731
hochopeper is offline hochopeper  Australia
Yes there is... 0xC1
Ie you will receive 0xAA,0xC1,DATA,0x55
DATA Will be a number between 0 and 9
Old 2nd May 2013, 05:37 PM   #2732
Rosendorfer is offline Rosendorfer  Poland
Hi
As could be that my English is readable, but from Your answers, I have feeling that I just did not have enough freedom/knowledge to convey my idea...
Well ..OK, let me do, just last try..
IN Simple …. I'm looking at ability of time control done in digital domain..... and rest of speaker control in old analogue way....
Again:
It is about having a bit perfect!!!, not re-sampled!!, jitter free!!! , actually untouched by DSP!!, signal chain, and being able, to do Time manipulation...
Now we do have analogue way of speaker "control" with few caps and inductors at hand and some woodwork to do loudspeaker right... or have to go with DSP, with all good and easy DSP things, but also..... well there are always some but's......
So...
Having ability of time delay control done in digital domain in way that signal is “unharmed”... possibly, could be very interesting for anyone trying to build speakers, without going DSP route.
And hire I'm just looking at Ian FiFo , as wonderful thing we have.
Because...FiFo Can Do Time delay, IT is doing it !!
But Again!! and Again!!
Not as FiFo with uncontrolled time behaviour but as Hardware that is done, ready and able of time delay.
But with NEW! firmware, to do programmable!! and controlled!! time delay of I2S stream.
Then of cause Second I2S stream would have to go to second synchronized!! with first Re-clocker ...as it “have to” go and it is intended do ..
I do not know if this is possible with current hardware and how much work it would take...but maybe, just maybe... it is possible !? And there would be No need to design and build new hardware.
But seems that as for now there is a rather question: not if it is possible? but more a question if that “Idea” could be interested or not, or maybe there is some major problem with it.
Most of Your answers goes: it is simple job for DSP....
Well, but there are still pretty strong and still going on “traditional” target out there...people that for any reason, nothing against DSP, just do not want use DSP...
Please have a look at MultiWay Loudspeaker forum , and see things there....
Bet that for many people there, possibly of having the ability of EASY and FREE playing "Time" with their speaker and still keeping their Gold-Silver-plated Delund Caps and 2kg Inductors, could be a "magic"...
Look at all the struggles that have to be done to get anything close to "Time Coherent" speaker, lot of people knowing what step response is, are looking at, horns, wave-guides, stepped baffles and asymmetric XO's....
Things easy can get pretty complicated and very expensive.
OK.. I know that “time delay” is not “full solutions”, and easy way to perfection, it is bit more complicated that that, but it would be absolutely valuable...
And as last thing:
MultiChanel FiFo I'm sure, will be real Ian "blessing" for DSP users...
But it is Not That Thing I'm talking about..... Well unless it will have implemented Time delay control between Chanels...on Its OWN Hardware and not rely on separate DSP processor.
OK I promise this was my last try...
Vox populi, vox Dei
Rosendorfer
Old 2nd May 2013, 05:45 PM   #2733
qusp is offline qusp  Australia
qusp's Avatar
we understood and answered you, both of us (hochopeper and I). Ian I dont think did quite understand though he did all the same give you an applicable answer, no way you reframe the question will change the hardware limitations
fifo is not doing time delay, it is delayed as a biproduct of what it is doing (it delays while it half fills the memory, which happens at a different rate depending on the exact samplerate ie. it happens synchronously as the data is clocked in). it is not a deliberate choice, or a controlled choice, just an unavoidable outcome
whos talking about a DSP processor? it could be done on DSP, though that is not what Chris and I were talking about. delaying one audio channel requires no resampling, no processing as such, it would be done on the computer and output as a second stereo channel with added delay. I must admit I have absolutely no idea what your objection is to doing something the easiest way with the most control (sample level), using tools that have already been designed for this exact purpose...
Old 2nd May 2013, 10:55 PM   #2734
Originally Posted by qusp View Post
no way you re-frame the question will change the hardware limitations
Dear qusp
I will have to disagree with You.....
There is No Hardware Limitation, FiFo HARDWARE Can do Time delay...
And starting easy way possibly can lead into trouble, just bit later....
If possible Please get through my lengthy mumbling...I have try to explain what and why really hard..
Rosendorfer
Old 2nd May 2013, 11:09 PM   #2735
bigpandahk is offline bigpandahk  Hong Kong
Thanks, will try.
Old 3rd May 2013, 03:42 AM   #2736
qusp's Avatar
I did read what you wrote, it was just saying the exact same thing that we both knew you were saying in the first post....
you restated it another 2 times because you didnt like the answers...
when you start with
but then insist on avoiding using the best tool for this exact job, meeting these exact goals, while describing something convoluted that requires considerable work on somebody elses part, to do exactly the same thing!! well... my attention starts to fade
the fifo must half fill its buffer before starting to avoid buffer under/overun, it does not flush its buffer between songs, where exactly would you have this sample level control take place while sticking to your own goals above, for example, when the memory is filled with 2, or even 3 songs of different sample-rate?
Originally Posted by Rosendorfer View Post
Dear qusp
Rosendorfer
Old 3rd May 2013, 07:39 AM   #2737
koldby is offline koldby  Denmark
koldby's Avatar
I still think the easiest way to make steady time delay is a shift register just before the DAC.
If you want different samperates, you could use a mux to chose witch output to use from the shift register and let the Fifo board manage the Mux. I believe you have data that tells you what the LRclk is (the led´s on the board), but I have not looked closely into this.
No need to reclock anything, as the delayed data is already "reclocked " out of the shift register.
There might be something I have overlooked, please correct me if I am wrong.
Koldby
What is Home Theatre without good sound?
Old 3rd May 2013, 09:13 AM   #2738
qusp's Avatar
for sure, there are many external solutions, but surely their realization is the domain of those who want them ... The easiest solution has already been covered, but Rosendorfer has some irrational issue with doing the exact same process..on evil computers or DSPs, composed of the exact same type of logical parts... lets forget the belief that expensive capacitors are in any way linear...
the fifo is capable of 44.1->384khz, thats one hell of a mux, but i'm sure you could break it down into 44.1/48* plus a multiplier. it would on the surface seem something that could be achieved with the PCM daughterboard.
Old 3rd May 2013, 02:36 PM   #2739
Hi Ian
while assemble the optional components for i2C isolation on the V1 board, found that the two pull high resistors R5 & R6, only pin 1 is connected to V3.3, pins 2,3,4 are to ground. Is it a bug on the PCB tracing?
Old 3rd May 2013, 04:32 PM   #2740
Hi
I'm absolutely agree with You!!
And that is almost exactly my "crazy"idea.
The only difference is that instead using MUX'es and other things,
I have been thinking, if if would not be possible to use FiFo Hardware with New Firmware!! to act JUST as "Buffer" with programmable length.
There is lot of memory and nice processor that possibly can communicate with Real FiFo and easily get current sample rate ..
All You would need to do simple programmable time shift...
But..well seems that is not catching up as I was thinking...
Rosendorfer.
Koldby
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
