Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 30th April 2013, 12:56 AM   #2711
hochopeper is offline hochopeper  Australia
Rosendorfer,
I'm sure Ian will respond in time, but I just want to mention that there has been machinations for a fully multichannel capable FIFO, begging from a few. I believe there is technical hurdles in making the master/slave.
I wouldn't recommend using the FIFO delay as a delay between two speakers for time alignment of drivers. The delay is dependent on the sample rate of the playback media so the delay is less for 192kHz than 44.1kHz for example. Also the delay is actually fluctuating within tolerances of the memory buffer due to long term variance of the clocks on either side of the FIFO. For this reason I don't think the FIFO delay is appropriate for that application.
A DSP module, followed by a multichannel FIFO reclocker and multichannel DACs would acheive what you want though. There are still technical details to be managed, including the need to have filter coefficients at every sample rate or re-sample the input to a fixed sample rate for use inside the DSP.
Old 30th April 2013, 07:22 AM   #2712
koldby is offline koldby  Denmark
koldby's Avatar
As far as I can see, the solution could be a simple shift register on the Data stream of the I2S AFTER the fifo. It should not jeopardize the jitter reduction of the FIFO as it is Wclk and Bclk (depending on the DAC chip) that must be held jitter free as far as possible.
Koldby
What is Home Theatre without good sound?
Old 30th April 2013, 07:52 PM   #2713
Rosendorfer is offline Rosendorfer  Poland
Dear Hochopeper
I know that my English sometimes could be not very easy to understand,
so I will try to refresh my "idea"..
Well first, I'm fully aware that in current firmware state FiFo delay is dependant on many factors and it is not my intention to use uncontrolled FiFo delay to achieve anything...
This what I'm thinking about is "idea" of using second FiFo hardware, means current gen PCB, memory and FPGA controller, but with new! firmware to delay I2S stream but in controlled and defined way.
Well I'm just thinking about: First FiFo with no changes, is doing all of hard job it is doing now and second "FiFo hardware" with new firmware just delays at programmable! time I2S stream taken from output of First FiFo and sends it to second Reclock board.
Well of cause we would need to have a way of being able to program the delay, as different speaker arrangements needs different delays,
This what I'm looking into is probably bit strange mix of traditional analogue speaker XO's with "good old caps" and inductors to get the crossing points and slopes and have the freedom of being able play "time alignment" of speakers in digital domain.
I have been playing with my speakers for last few months, and seems to me that this could be pretty interesting solutions.
And as for waiting for "planed" multichanel FiFo to be working with DSP..... I'm sure that this is extremely interesting stuff, and probably many guys using DSP's are waiting for that....
But my idea is much simpler and fundamentally different thing.
I'm looking for some help with "time" in digital domain but do not want go full blown DSP.
And there are not that many ways to have programmable time delay, bit perfect! and "jitter free" second I2S stream.
So maybe this possibly could be interesting and just new Ian FiFo feature.
And as for Koldby idea of simple buffer or shift register.
Koldby
Well, been thinking about that and again not an expert, but for me it seems that "simple shift register on the Data stream" would be OK if we were not into all of that HiRes stufff and different Fs like: 44,1k ; 48k, 88,2k, 96k, and so on, That makes simple shift register bit tricky, our buffer have to be aware what frequency we are playing and have to adjust buffer length to keep delay constant for all frequencies.
But again, maybe all we need is something much simpler than FiFo and Ian in his free time could come out with some small Add On card that could be doing simple time delay job.
Anyway not sure if that could be interested for anyone, but well why not ask.
Best Regards
Rosendorfer
Old 30th April 2013, 11:56 PM   #2714
Rosendorfer,
Your english is great, really! But thank-you for re-iterating and clarifying a few of your thoughts, an interesting idea.
The idea is to duplicate each L/R signal, produce a 4ch i2s output from 2ch, with two of the channels delayed. ie L, L-delay, R, R-delay?
The problem is that re-clocking still needs to be the final stage, any delay and other functions need to happen before that, the same way as the I2S to PCM adapter is added to the chain prior to reclocking. The solution you're suggesting needs 4channels of i2s reclocking, which I don't think is possible without redesign of the clock board(s).
Chris
Old 1st May 2013, 12:31 AM   #2715
qusp is offline qusp  Australia
qusp's Avatar
the fifo doesnt know what time it is in an absolute sense, only that time is passing, there is also no means of syncing 2 boards, I asked about this possibility long ago, but with them synced and me doing crossover and phase alignment on the computer. they need to be able to be synchronized in order to delay one a specific/constant amount.
it seems like a LOT of trouble to go to for something that would really IMO be better done in DSP anyway, in fact it would be trivial. I would certainly prefer the multichannel fifo done first
Old 1st May 2013, 01:05 AM   #2716
The point here is that you could duplicate L/R. The problem is that you need a new reclocking board to enable that.
A single delay board could be programmed to have delay with time represented as number of samples at each sample rate, and sit in the system like the I2S to PCM board, I can see how that could work. The problem with Rosendorfer's variation is the re-clocking stage, it would need a multichannel re-clocking stage.
I think it would need either a mutlichannel FIFO+Reclock, or a new intermediate board and new multichannel reclock board.
I agree!
Old 1st May 2013, 02:44 AM   #2717
qusp's Avatar
maybe you should read my post again I know very well what he could do, if we had the power t just pretend that hardware exists, I asked about doing it more than a year ago... my dacs are duplicated L/R, pretty logical progression to want to duplicate fifo L/R, but I didnt want to use delay, just access to 4 channels of buffer/reclock, which brings us to...
Old 1st May 2013, 03:13 AM   #2718
iancanada is offline iancanada  Canada
iancanada's Avatar
I'll open a new thread for the multi-channel DSD/I2S FIFO project soon. It would be totally a different project because of the architecture.
I'm super busy recently to release a new product line for my boss...
Ian
Old 1st May 2013, 03:19 AM   #2719
Ian
Wow, I knew you had been thinking about it Ian, I didn't realise it was so close. Work is important, please make sure you're able to keep your hobby projects fun and without pressure or rush!!
Old 1st May 2013, 03:22 AM   #2720
qusp's Avatar
Ian
Ian, I hope you didnt read that the wrong way, I know it'll come when it comes, i'm in no huge rush, but this news does make me happy
my reference to bringing it up a year ago was not a hurry up, just reminding that i've covered pretty much this exact scenario before long ago
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
