Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter - Page 266 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 6th April 2013, 04:56 PM   #2651
nvduybom's Avatar
Hi Ian,
I upgraded to double dual clock with crystek 45Mhz & 49Mhz. The sound improved, but I get the error when playing the files with sample rate 44.1 Khz & 96 Khz .
- Sample Rate 96KHz :
All times playing 96kHz files then all Leds on Clock board is flashing. On FIFO, the Led "Emty" is light. No sound.
- Sample Rate 44.1kHz :
On Clock board, The Leds 48Khz & 96Khz is light. On FIFO, the Led "Emty" is light. No sound.
But I noticed that when I playing the file 88khz or 176 Khz, then continue to playing the files 44.1 Khz is ok.
I read but not seen anyone with this error.
Ah, it is necessary to add the 100n capacitor and 1uF for Crystek adapter board ?.
I use PC with Jriver 18 + Amanero .
Thank you .
http://www.vnav.vn/forum
Old 7th April 2013, 06:08 AM   #2652
nvduybom's Avatar
This error is caused by U1 jumper on Clock board , (long time I think caused by software & firmware ). I see it loose and replace new jumper. Everything works fine.
Old 7th April 2013, 02:48 PM   #2653
iancanada's Avatar
Looks good. Glad you fix it. Both hardware and software were confirmed many time should be no problem.
Nice weekend.
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 7th April 2013, 10:20 PM   #2654
Greetings,
I reolved my issue with the Si clock and synching the es9023 dac. I noticed that the clcok was set to 90/98 Mhz. The es9023 didn't like that speed. I switched to 45/49 and all is good. tried 44.1 and 48khz files without any glitch.
Now, I would like to drive a dual mono with the Si clock board in asynch mode for now. So I soldered the ufl on the second I2S outputs. I get no signal on the second set. Only one channel (N the top set) is functionning.
Is there anything else needed other than the ufl connectors? Jumper I am missing perhaps?
regards.
Old 7th April 2013, 11:56 PM   #2655
mcluxun is offline mcluxun  United States
Hey all
I'm trying to make a case of this kit including the spdif board.
Did any one make a drill pattern for spdif board before?
I searched this thread but didn't get any luck.
Old 8th April 2013, 02:22 AM   #2656
iancanada's Avatar
Originally Posted by necplusultra View Post
Greetings,
regards.
Hi necplusultra,
Here is the schematic of the output section of the Si570 clock board. It would easy for you to address the problem with it.
Hope it helps.
Ian
Old 8th April 2013, 02:25 AM   #2657
iancanada's Avatar
Originally Posted by mcluxun View Post
Hey all
George has the drawing.
Ian
Old 8th April 2013, 02:25 AM   #2658
I just noticed this hadn't been addressed. You should not need those caps when using the Crystek XO. The Crystek units have decoupling internally I believe so do not require additional decoupling on the adapter PCB.
Old 8th April 2013, 04:03 AM   #2659
nvduybom's Avatar
Thanks you ,
I thought why not practical test? . After listening to both cases, I likes the sound with no capacitors . The sound more open, especially in high frequencies .
Old 8th April 2013, 11:02 AM   #2660
BKSL is offline BKSL  Slovakia
to iancanada:
Is it possible to disable digital filters in your "hardware" to achieve untouched digital input on analog side? No decimation, no DC removing etc.
If i connect 4 signals of I2S bus from CMI8788 chip to your hardware, should it works ?
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1373 13th January 2017 06:45 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3007 7th January 2017 02:57 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 01:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 10:22 AM
Copyright 1999-2017 diyAudio
