Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th February 2012, 12:26 PM   #251
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
thanks!! hey how do you reckon the fifo will go with the upcoming possible DSD over USB standard? it requires that the data is not resampled, but buffered is ok I would think
Old 24th February 2012, 01:34 PM   #252
vzs is offline vzs  Europe
Hey Ian,
I have some question regarding interfacing your board with my system.
As my AD1865 DAC needs a 18bit LSBJ stream I'm using a simple converter board with a shifter logic like this: link to convert 32bit I2S to 18bit LSBJ. Basically data is shifted with 13 clocks.
- As I don't want to use double output reclocking -first with your board then with mine - I thought I could create a small data-shifter board and plug it between the FIFO board and single XO clock board, therefore the clock board would receive an LSBJ stream with data shifted. Am I right that the reclock part does not care about what it reclocks, so this approach can work?
- How does the FIFO board receives the master clock from the single XO clock board?
- What is the reclock frequency: 128Fs or 256Fs?
Thanks!
Zsolt
Old 25th February 2012, 02:00 AM   #253
iancanada's Avatar
Originally Posted by vzs View Post
Hey Ian,
Thanks!
Zsolt
Hi Zsolt,
I like AD1865. My PCM7040 sounds perfect!
I analyzed your schematics, the answer is yes. You could insert your converter boare between fifo and single clock board. The default reclock frequency is 256Fs for the single clock board. FIFO receive the master clock from the FFC/FPC interface cable. You are right, my reclock circuit reclock signals by the master clock no matter what they are. Logiclly, there is no difference reclock at 128Fs or 256Fs. However, reclock by master clock directly will have less jitter.
Have a nice weekend.
Ian
Old 25th February 2012, 08:41 AM   #254
regal is offline regal  United States
Originally Posted by iancanada View Post
Hi Zsolt,
Ian
So you do mean this unit outputs true Phillips 16+16 I2S (if it is input) as opposed to the difficult 32x32bit wordlength format that has recently come about with most of the usb implementations ?
Old 25th February 2012, 05:15 PM   #255
iancanada's Avatar
Hi regal,
This I2S FIFO accepts true 16bit to 32bit I2S input range (actually sck input from 32fs to 64fs). Internally, the FIFO memory is true 32bit processing. Output sck is 64fs (I2S standard, same as most DIRs). No problem if you feed true 32bit I2S, bit perfect confirmed.
Ian
Old 25th February 2012, 07:28 PM   #256
nicoch58's Avatar
Salas low volt shunt Reg ! better then this ......
Sic58
Old 25th February 2012, 10:57 PM   #257
1audio is offline 1audio  United States
Can you defend your claim about the salas regulator? What use case? Please contribute more details.
Sent from my T-Mobile G2 using Tapatalk
Demian Martin
Product Design Services
Old 25th February 2012, 11:22 PM   #258
nicoch58's Avatar
defend what ??
just use search ....
Sic58
Old 25th February 2012, 11:39 PM   #259
"Salas low volt shunt Reg ! better then this ......"
Not constructive or useful. How is it better? The noise floor is higher. . .
Demian Martin
Old 25th February 2012, 11:53 PM   #260
nicoch58's Avatar
"The noise floor is higher"
Damian sorry if is not sufficient good ,but as DIY is well supported with guide /pcb/GB
Sic58
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1715 Today 08:15 AM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1303 10th May 2013 05:19 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright ©1999-2013 diyAudio
