Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 9th March 2013, 12:33 AM   #2571
iancanada is offline iancanada  Canada
iancanada's Avatar
Hi Guys,
I'm currently on vacation and out of town. I'll try to provide support as possible as I could.
A guy got problem with TPA trident reg working with si570 board, he measure (5V input) the output was just 2.2V rather than 3.3V. I notice somebody else has no problem with this issue. But he may did some mod.
Any help to address this problem? Thank you.
Ian
Old 9th March 2013, 12:59 AM   #2572
qusp is offline qusp  Australia
qusp's Avatar
hmm, isnt the trident set for 3v3 by default? trident does need a bit more than 5v to work happily in my experience, more happy with 5v5 (for 3v3-3v5vout), but I only have experience with the one on the BII, not the separate tridents sold now. the max load current for the trident is 100mA, which is not quite enough for the Si570 modules 150mA
Old 9th March 2013, 01:16 AM   #2573
makumba1966 is offline makumba1966  Poland
Originally Posted by iancanada View Post
Hi Guys,
Ian
May be two reasons : too low ccs current ( should be at least 200mA ) and too low Vin ( should be at least 5.25V). Trident without mod have 80mA CCS.
Old 9th March 2013, 01:20 AM   #2574
qusp's Avatar
have you pointed a thermal camera at them running that high current? I worry for their longevity doubling the recommended max and noise performance could easily be degraded
Old 9th March 2013, 12:27 PM   #2575
Russ White is offline Russ White  United States
Russ White's Avatar
Regarding the 3.3V Trident - it is a shunt regulator. It is very likely just the CCS is too low for your application (not certain how much you need). They come from us configured for use with the Buffalo DAC.
As long as it is a V3 Trident you *should* be able safely increase it to 200ma or so at 5 - 6V input. 5V is usually just fine. You will need to check this for yourself only because 150ma is as far as I have pushed mine - so that is the maximum we state on the site. If it is a V1 I would not try it.
Just monitor the temps - if you see > 65C at the transistors then it is too hot.
Reduce R4 until the desired current is reached. Adding a parallel resistor works great. You can even rig a suitable rheostat connected pot and adjust as needed, but I would replace the pot with a resistor once I know the exact value wanted.
Remember when testing the trident you should provide a dummy load so as not to over-stress the shunt transistor which will otherwise have to shunt the entire CCS current at 3.3v drop (which would not be the case when it is installed in the application).
Also the best bet for getting answers about TPA modules is on our forum. Fortunately someone happened to point me here.
Anyway glad to help. Good luck.
Cheers!
Russ
Less pulp more juice Twisted Pear
Audio
/Twisted Pear Audio Blog
Old 9th March 2013, 01:11 PM   #2576
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Thanks for dropping Russ!
Old 9th March 2013, 03:05 PM   #2577
qusp's Avatar
Russ, you should change the copy on your website, as I dont have V3, I just repeated the MAX load current stated on the trident webpage.... so its not my misinformation. V1 also does not perform optimally with 5v, better with 5.25-5.5v in my experience.
perhaps you are playing it safe with the general recommendation? fair enough. its a tiny SMD shunt, I didnt expect adding 50% on top of the max load spec would be wise.
Old 11th March 2013, 04:02 AM   #2578
lxiaob is offline lxiaob
How should I connect the QNKTC USB-I2S board to this kit? http://www.qnktc.com/usbmod.php
@iancanada, do you have time to check that out?
Old 12th March 2013, 01:21 PM   #2579
hochopeper is offline hochopeper  Australia
Originally Posted by lxiaob View Post
How should I connect the QNKTC USB-I2S board to this kit? Q N K T C USB-I2S Module and Analog Board
I think you want to take the signals with the 'DA_' prefix plus the mclk out signal. They're all described on the schematic at the qnktc website link that you posted. These will provide the i2s input that you connect to the FIFO. You will need to mount the on board oscillators on the usb-i2s board to provide the 11.2896 and 12.288MHz MCLK that is required by that board.
Old 12th March 2013, 04:34 PM   #2580
Alcaudon is offline Alcaudon  Spain
Hi guys,
I'm just trying to figure out what to use to power my fifo-isolator-si570 combo, and I definitely could use some advice from the experts here.
Iím using TPA Placids in my build, and the one powering the BIIIES heats up to 60-64 C drawing 460 mA, so Iím a little concerned about the heat that another shunted reg would produce with around 650 mA (according to Ianís docs, thatís what the fifo and the Si570 need). Besides, Iím not sure if a placid can go up to 650 mA, probably not without any mods (bigger heatsinks for sure).
Do you guys think that a sigma11 could be a suitable option?
Iíve been looking trough the thread and seems like some of you are using Salas shunted reg and others are using batteries. WellÖ hereís where I have to confess my complete ignoranceÖ can anyone help me a little bit with the passive battery management board? I would really appreciate if someone could point me to an appropriate set of batteries (LiFePo4 maybe?) and a suitable battery charger. What do you use as control voltage? (the fifo's 5V output?)
Many thanks for your help!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
