Go Back   Home > Forums > Source & Line > Digital Line Level
Old 1st March 2013, 10:49 AM   #2511
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
well its not that far off at 4.17µVrms 100khz bandwidth and whether the trident maintains that same performance at 200mA in reality would be interesting. so I think your scoffing at the idea of an IC being a discrete regulator is a bit unfounded. also 2.9µVrms is hardly world beating as discrete regs go though.
its a nice small discrete reg, but ICs are catching up, certainly its got wider capability in voltage and current
Old 1st March 2013, 12:32 PM   #2512
andrea_mori's Avatar
Originally Posted by makumba1966 View Post
Even with TPA, it seems to me, that XO dual board had a little better timbre.
Not a big surprise for me.
Subjective impressions remain subjective, while technical specs are objective.
Please, compare the phase noise from their datasheet between the CCHD-957 (not more than a standard XO from the shelf) and the Si570. In these datasheets you can find the explanation of your impression.
Typically (not from me, but in most literature from the guru in this matter), higher phase noise decreases the dynamic range, and so our ears feel the sound less natural, mostly in the midrange frequency.
Low Q oscillators with PLL usually perform worst than oscillator with higher Q without any PLL in digital to analog conversion.
Old 1st March 2013, 12:49 PM   #2513
I'm not sure if this is the main reason. IMO Si board need several hours more break-in to perform a meaningful comparison. With TPA board it sounds very nice to me, and I do not have any preasure back to CCHD
Old 1st March 2013, 12:58 PM   #2514
qusp's Avatar
andrea loves to beat incessantly on the si570. believes he can distinguish differences in jitter down into the femto seconds
Old 1st March 2013, 02:09 PM   #2515
jeremy loves to beat incessantly on subjective impression forgetting technical specs
we have different point of view, the technical point of view with objective measurement (the old thought school) and the subjective point of view without any demonstration (the new and creative thought school)
Hint of the day: there are thousands of documents on the internet explaining how phase noise, or if you prefere jitter, affects the sound in digital to analog conversion
There is not femto seconds difference from the 2 oscillators: from the Si5770 datasheet -112dBc@100Hz is a BAD performance, also if was measured at 120MHz frequency. Theorically you can subtract 6dB for each division by 2, pratically the phase noise remains the same (you can understand the reason in the thousands of documents on the internet, just read a bit)
Old 1st March 2013, 05:49 PM   #2516
Can you say Audio?
subjectively, this has been very interesting. I switched from the Dual Clock board (Isolator, S11 powering DAC & clock board, with TPA inline for dual clock board). to the Si570, TPA powered. Initial impression was slightly less timbre, but more smoothness/analog sounding (something I attributed to the higher clock speeds). Listened for a day and it sounded good; better as the day went on. Switched back this morning to the dual block board (CCHD-957's by the way), and a slight increase in Timbre (missed), but... I think overall the Si570 might be the winner. More listening to come....
Ian - a heartfelt thanks for your time/effort that allows us audio/diy geeks to play on this level. You've allowed me to entertain the absurd pursuit of the minutia. :-)
Old 1st March 2013, 05:49 PM   #2517
glt is offline glt  United States
Originally Posted by roender View Post
This is not a surprise given the noise of trident regulator: 2.9uVrms, 100Kh bandwidth
The output impedance is almost the same as TPS7A4700 regulator.
I suppose no one imagine an integrated regulator will beat a well designed and implemented discrete regulator :-)
Is that value a measurement or simulation?
www.hifiduino.wordpress.com
Old 2nd March 2013, 04:45 AM   #2518
iancanada's Avatar
You welcome MisterRogers. Mine is similar to you.
I have a couple of reg boards for my Si570, even same board with different capacitors, as well as 3.2V battery cell. I always can't decide which one is I want . That's why I designed a socket for external reg board. Every small change could be heard a this level.
Have a nice weekend.
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 2nd March 2013, 11:32 AM   #2519
After several hours of listening i decided that Si board with TPA trident sounds too "technical" to me and back to TPS. I'll wait some days now for burn-in before comparing with dual xo and other regs.
Old 2nd March 2013, 11:58 AM   #2520
regal is offline regal  United States
Ian
either permutation is so superior to anything our ears have ever heard with regard to jitter performance it just amazes me that you are hearing differences. I mean at this level, jitter should be completely out of the question. Very odd. Makes me think oscillation/intererfance or some other rf phenomenom is occuring.
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1725 Yesterday 08:02 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1304 23rd May 2013 03:43 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright ©1999-2013 diyAudio
