Go Back   Home > Forums > Source & Line > Digital Line Level
Old 25th February 2013, 08:45 PM   #2491
Originally Posted by jbercovici View Post
Hello,
newbye on this thread. I will have a Buffalo IIISE with Paul hynes regulator and a tube Lampizator output stage.
I'm looking also for a USB/I2S converter (Luckit Xmos or Amanero : advice what is the best one, or others ???).
Would it be a nice improvment in SQ to add between the USB/I2S and the Buffallo to add the the Ian FIFO +dual XO reclocker ??
Yes, it is a must. and when you want tubes why not use Broskie's Unbalancer instead ?
Old 26th February 2013, 09:55 PM   #2492
mcluxun is offline mcluxun  United States
Failed in soldering the backdoor kit.
I got my kits yesterday, and I was trying to do the i2s backdoor on the spdif board.
Everything went well I finished soldering and pluged the cable in.
When I tried to pull the cable out from the socket, bad thing happened, I ripped the contacting dot R24. Now I wont be able to fix it, I guess I have to wait for the next group buy then.
Old 26th February 2013, 10:01 PM   #2493
Can you say Audio?
Sorry to hear mate. Send some close of photos of the state of things; it can often shake loose some thoughts/suggestions. If it's an issue with not being experienced with SMD parts, I or others might be able to help. Don't give up just yet.
Old 26th February 2013, 10:09 PM   #2494
Old 26th February 2013, 10:14 PM   #2495
Here is the picture, sorry for the bad quality
Old 26th February 2013, 11:14 PM   #2496
iancanada's Avatar
Don't worry.
Try small enameled wire, soldering one end on the Pin which connected to R24. Loop the wire to the back of the PCB through the hole of TP3. Scratch a bit on the trace connected to R24. Solder the other end of the wire to the appeared copper trace.
Please make sure you have enough temperature when soldering the ground plate like the wings of the SMT connectors.
Good luck.
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 26th February 2013, 11:51 PM   #2497
Originally Posted by iancanada View Post
Don't worry.
Good luck.
Ian
Thank you Ian
For future inference, my solder was on 610 f.
I will try to fix it tmr.
Cheers
Liang
Old 27th February 2013, 12:41 AM   #2498
Received the i570 yesterday, have to modify the Arduino code for the new clock board. Another big headache for me
Old 27th February 2013, 01:35 AM   #2499
iancanada's Avatar
To run it, you don't need to modify anything. But if you want to add features....
Step by step
I'll try the Si570 chips you sent to me one I get time.
Ian
Old 28th February 2013, 08:34 AM   #2500
nvduybom's Avatar
Hi Ian,
Can I change the default input with SPDIF board? .
Van Duy
http://www.vnav.vn/forum
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1304 23rd May 2013 03:43 PM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1724 22nd May 2013 06:50 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright ©1999-2013 diyAudio
