Go Back   Home > Forums > Source & Line > Digital Line Level
Old 30th January 2012, 03:44 AM   #241
qusp is offline qusp  Australia
Sometimes a square peg fits a round hole just fine
qusp's Avatar
Originally Posted by iancanada View Post
I did a little toy. I connected an A123 LiFeP04 battery to a 14pin IC socket. This configuration works as an adapter bypassing the power of the PCB. So the battery could power the XO oscillator directly from the socket as a reference without changing any other function. The output voltage of LiFeP04 is just around 3.3V. This little toy is really working.
I’m looking for power supply which comes with equal or closing low noise performance than a batter. But I’m not lucky so far. It’s really hard to measure if the PUS output noise is low, especially within wide bandwidth. However, by compare with the battery reference, it’s very easy to tell which one is better. I did some research by making use of this reference, the result was very interesting.
It’s also available that replacing the battery with other PSU to be evaluated.
hey mate, any chance you have some of these little dip pcbs around? I should have asked for a few, i'll send you some coin and money for postage.
where did you get the A123? that particular model is the most pirated and if you didnt buy it direct from A123 or an official a123 reseller, of which there are maybe 2, then you have fake or grey market there.
Old 1st February 2012, 02:47 AM   #242
iancanada's Avatar
You mean the little adapter PCB? It works very well with CCHD975, otherwise you have to solder flying wire. I ordered 20 of them for prototype, may still have something left. will throw a pair of them to you. Don't worry about the postage, buy me a cup of coffee .
Ian
Old 1st February 2012, 03:45 AM   #243
qusp's Avatar
hehe latte fine? yes those are the ones, they should fit the other Crystek (sp) parts too. flying wires on a master clock seems about the worst thing you could do. while you were at it, did you get a chance to scope out these sorts of differences? maybe these things arent all as meaningful as you would think.
Old 5th February 2012, 05:05 AM   #244
iancanada's Avatar
Default Simulating Demian’s regulator
Demian posted a low noise regulator here: http://www.diyaudio.com/forums/digital-line-level/192465-asynchronous-i2s-fifo-project-ultimate-weapon-fight-jitter-11.html, which was specialized for powering the oscillators.
I did some quick simulation yesterday. I was mainly focused on PSRR simulation. I don’t expect the load response performance because of the LPF on the feedback pass.
1. The first simulation shows the PSRR was 1dB at 1Hz and 10dB at 10Hz. The voltage drops on Q1 was too low and Sziklai pair didn’t run at optimized range.
2. I raised the DC input to 7V, see the second simulation, the PSRR went 90dB at 1Hz, very good low range. However, it dropped to 52dB around 12Hz. There might be a pole.
3. I remove C5, see the third simulation. We got perfect PSRR, greater than 80dB throughout 1Hz to 1.1 MHz.
4. I got the noise simulation spectrums, yes, it’s very low.
5. The power up time was 600ms, any way, we need making some compromise.
Some possible notes,
1. The main noise contribution would be the input, especially for the high frequency noise, because the PSRR start dropping below 60dB from 6 MHz.
2. Only suitable for static load (resistor load). The LPF corner frequency is too low.
3. Be careful the low frequency (below LPF) 1/f noise from voltage reference, I don't think it was included in the SPICE model.
Ian
Old 5th February 2012, 07:21 AM   #245
1audio is offline 1audio  United States
The model for the TL431 will oscillate at low frequencies if C5 is less than 20 uF if present. The actual part in this application shows no signs of oscillation. The model is not fully representative of the part. It might be better to think of the TL431 as a servo steering the output voltage to the target. The circuit works fine with a resistor divider for the reference voltage, but won't compensate for line, load and thermal effects.
It does work well with a 5V input. I'm surprised you are getting different results. It may be the TL431 model. I can assure you it works pretty well when built with the parts as shown. I'll play with the sym some more and also try to get a working regulator to misbehave.
Demian Martin
Product Design Services
Old 5th February 2012, 05:38 PM   #246
Default Updated circuit model
I have updated the circuit adding the stabilization necessary for the LT1431 model to get it to work. I'll check the real circuit later today to see if there is evidence of the instability. In this form the isolation is quite good up to 1 MHz. Above that the capacitance across the active devices shunts any isolation. Small inductors or ferrite beads would be the appropriate enhancement.
Changing R3 from 100 Ohms to 2200 Ohms doesn't degrade the performance and reduced the extra current significantly (-8 mA). The output impedance goes up but that isn't important for powering a crystal oscillator.
I don't know if the file is compatible with your simulator but the changes should be pretty easy to map across.
There is more discussion about this circuit here: Open-source USB interface: Audio Widget
Demian Martin
Old 7th February 2012, 12:57 AM   #247
iancanada's Avatar
Thanks Demian. The simulation result didn't mean it not work with 5V input. It dose work! The only thing is with 5V input, the line regualtion performance is not that excellent. But if we increase the voltage a little bit, says 7V (actuall 6V is already OK), the line regulation is gonna be much much better(PSRR above 80dB from 0-1.1MHz). I use Multisim, the model might be a bit different from LTspice, but won't be too much. I like the idea, reducing the noise by LPF the voltage reference which was suspected to be the biggest noise source. But all the SPICE noise analysing is based on the noise model of transistors and resisters. It would be very hard to get accurate noise simulation reslut if TL431 model is not based on the real internal components and circuits. Ian
Old 24th February 2012, 03:03 AM   #248
iancanada's Avatar
Default V1.0 documents
Attached files are the updated V1.0 techincal documents.
Ian
Old 24th February 2012, 03:34 AM   #249
qusp's Avatar
hey Ian, got the adapters yesterday thanks mate. i just bought cchd957 yesterday just in the 22.1x for starters till i get around to working something out with the DsPLL and i plan to play with your boards this weekend if time permits
Old 24th February 2012, 12:20 PM   #250
iancanada's Avatar
Good luck qusp
Ian
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 836 Today 05:42 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1111 Today 03:36 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Page generated in 0.13487 seconds (50.57% PHP - 49.43% MySQL) with 11 queries
