Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter - Page 224 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 24th January 2013, 10:08 AM   #2231
Originally Posted by qusp View Post
as I understand it there is a lot more than changing clock speeds needed to mod amanero
I was thinking about the cheap Acko isolator relcoker plus the si570 as RFCK. Wouldn't this work?
Originally Posted by hochopeper View Post
Si570 doesn't talk i2c ... it needs a UART.
TBH I haven't read Ian's implementation but according to the SI570/571 datasheet (page 17) it would seem to support 2 wire I2C through pins 7 (SDA) and 8 (SDL).
Old 24th January 2013, 10:29 AM   #2232
This will work as long as you are wanting asynch re-clocking with Acko's board. See below.
Yes the Si570 chip itself has an i2c interface. Ian has an on board controller that communicates with the Si570 and it is this controller that provides a UART API for external control of the board. This ensures that the external controller gets FIFO events (change of input freq) that would not be possible if he only provided the i2c port.
In your application I think setting a fixed freq and using asynch reclocking would be the best bet.
Under Construction:Ian's i2s FIFO wiki
Old 24th January 2013, 11:02 AM   #2233
dvb projekt's Avatar
Originally Posted by Popolvár View Post
Ian, great news!
Maybe too late (the frequency groups were here for some time already) but I will try to kindly ask:
Would it be possible to add one more group (or modify the group1) also for older DAC chips like WM8741 or AK4396 that support master clocks up to 36Mhz (so 128fs is required)? This would support 176.4kHz and 192kHz sampling frequencies for those chips.
//Group0:Si570 frequency and *Fs combination for very low mclk range
{F112896, 256*FS}, //2 44.1 KHz
{F122880, 256*FS}, //3 48 KHz
{F225792, 256*FS}, //4 88.2 KHz
{F245760, 256*FS}, //5 96 KHz
{F225792, 128*FS}, //6 176.4KHz <---
{F245760, 128*FS}, //7 192 KHz <---
{F903168, 256*FS}, //8 352.8KHz
{F983040, 256*FS} //9 384 KHz
There is no LED for 128fs (I would have no problem with that) but it is probably too late to ask before GBIV. If it is so then I could get one double clock board for experiments with older chips.
Thank you.
That´s what i have in mind with my TDA1541A NOS, if i would use the Dual Clock with two Crystek CCHD-957 (22.5792 MHz/24.5760MHz) XO´s.
Is that possible with the Dual Clock?
44.1 kHz - 512*fs --> 22.5792 MHz
48.0 kHz - 512*fs --> 24.5760 MHz
88.2 kHz - 256*fs --> 22.5792 MHz
96.0 kHz - 256*fs --> 24.5760 MHz
176.4 kHz - 128*fs --> 22.5792 MHz
192.0 kHz - 128*fs --> 24.5760 MHz
Oliver
Reference TDA1541A DAC project PCB´s / Tube-I-zator PCB
Stock status in my Blog
Old 24th January 2013, 11:20 AM   #2234
Thx Hochopeper. My intention was going for sync but if I2C is not available then obviously no cheap easy way to get it. I'm not sure if async would work with non ESS ICs.
Old 24th January 2013, 11:21 AM   #2235
Hi Oliver,
That is the functionality of the default jumper setting for the DualXO board. The generic clocks provided with the DualXO are exactly those frequencies. Refer to page 3 of Ian's DualXO manual.
Chris
Old 24th January 2013, 11:29 AM   #2236
Hi Oliver,
Chris
Thank´s Chris.
Old 24th January 2013, 11:57 AM   #2237
Originally Posted by iancanada View Post
Hi regal,
This I2S FIFO accepts true 16bit to 32bit I2S input range (actually sck input from 32fs to 64fs). Internally, the FIFO memory is true 32bit processing. Output sck is 64fs (I2S standard, same as most DIRs). No problem if you feed true 32bit I2S, bit perfect confirmed.
Have a nice weekend.
Ian
Originally Posted by dvb-projekt View Post
That´s what i mean. The TDA1541A limit for BCK (SCK - FIFO out) is 6.4 MHz.
If FIFO´s SCK = 64*FS than we have:
44.1 KHz --> 2.8224 MHz
48 KHz --> 3.720 MHz
88.2 KHz --> 5.6448 MHz
96 KHz --> 6.144 MHz
176.4 KHz --> 11.2896 MHz
196 KHz --> 12.544 MHz
If this above is correct, i couldn´t use the 176.4 and 196 KHz sampling rates.
My last concern driving the NOS TDA1541A with 176.4 kHz and 192 kHz.
As the FIFO SCK output is 64fs and i think the SCK output of the Dual Clock is equal, correct?
If so i could cancel these two sampling frequencies, unless the SCK would be switched to 32fs.
Old 24th January 2013, 06:46 PM   #2238
iancanada's Avatar
When we talking about xFs, we mean the relationship between MCLK frequency and Fs .
TDA1547 is running at NOS mode do not need a MCLK, so xFs parameter is meaningless for TDA1541. Please just think about it .
Ian
Twitter: @iancanadaTT GBVI: FIFO II, Dual XO II & other accessories
http://www.diyaudio.com/forums/group...ml#post4357477
Old 24th January 2013, 07:09 PM   #2239
iancanada's Avatar
I guess you are concerned about true 16bit I2S (in which sck=32Fs) and 32bit I2S(sck=64Fs) issue.
I confirmed many times, TDA1541 accept 32bit I2S (with 16 bit data) without any problem, That's the native feature of Philips I2S protocol .
But if you are thinking it would be better feed TDA1541 with true 16bit I2S, that's fine. In this case, I would suggest you useing the I2S to PCM daugher board after clock board. The daughter board was specially designed for DACs running at NOS mode. It's not only capable for true 16bit output, but also can stop clock after loading data in order to minimizethe noise floor.
But unfortunately it's still not available for GB so far.
Ian
Old 25th January 2013, 12:42 AM   #2240
iancanada's Avatar
Default Si570 Clock Board -Native support DACs in dual mono
Si570 clock board was designed be capable to support DACs in dual mono configuration natively.
It has two MCLK u.fl output sockets with drivers independent from each other. Each of the sockets was driven by a dedicated clock driver to ensure high quality low jitter MCLK signals being fed into both DAC blocks. Carefully designed PCB layout matches the impendence to 50ohm transmission lines which optimized to the good signal integrity (SI) driving u.fl coaxial cables.
Additional group of u.fl socket footprints of I2S output signals for the second mono block were placed at back side the PCB. Each I2S output signal has its own source termination network to reduce both reflection and cross talking.
To run DAC in dual mono mode, I’m highly recommended using u.fl coaxial cables with same length to guarantee signals arrive at each block at same moment. Please keep in mind, every 1 inch 50ohm coaxial cable will cause roughly 120ps delay on signal!
That’s one of the black magic of a digital cable: vibration and jitter
Ian
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3024 19th February 2017 10:14 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1373 13th January 2017 06:45 AM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 01:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 10:22 AM
Copyright ©1999-2017 diyAudio
