Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 17th January 2013, 06:45 AM   #2131
nvduybom is offline nvduybom  Viet Nam
nvduybom's Avatar
It is what I have been looking forward .Hope you support includes all components or finished kit.
Old 17th January 2013, 08:14 AM   #2132
qusp is offline qusp  Australia
qusp's Avatar
I would doubt that very much
Old 17th January 2013, 08:36 AM   #2133
roender is offline roender  Romania
roender's Avatar
Isn't much better to isolate the USB port rather than I2S? I mean using a true USB galvanic isolator capable to provide to the output USB port power from a battery pack or from an external power supply and not from PC.
Old 17th January 2013, 08:41 AM   #2134
qusp's Avatar
why is it any better? the i2s is isolated then reclocked, certainly it seems as though the ESS prefers the clock domain to be powered/grounded on the dac side. here it makes no difference where it happens as long as its before the reclocking stage.
weve been through all of this. there is a theoretical benefit to isolate the i2s input as well, and then again before the reclocker, but both of these isolate the reclocker from the USB ground, for the same result. isolating the USB is not cheap and does not provide additional benefit as far as can be told.
we cant even prove better, let alone 'much better'
Old 17th January 2013, 08:45 AM   #2135
roender's Avatar
IMHO, any I2S isolator will add jitter and there is no reclocking stage into Ian's I2S universal isolator board.
Old 17th January 2013, 09:59 AM   #2136
qusp's Avatar
umm, so what are you talking about? some unnamed random application of the universal isolator unconnected to the subject of this thread?
I presumed since..you are in this thread, you might be talking about some application that had a connection to this thread. the universal isolator, was built as..a universal isolator. a USB isolator, may not be better at isolating i2s at all and is not really very universal as an i2s isolator
its like telling someone who just eaten a really nice chicken dinner that beef might have been more enjoyable
Old 17th January 2013, 10:04 AM   #2137
roender's Avatar
Exactly, used as Ian description: an Universal I2S isolator.
As it is designed now, it doesn't have any reclocker circuit in order to attenuate the added isolator jitter
Old 17th January 2013, 10:32 AM   #2138
hochopeper is offline hochopeper  Australia
It could be readily assumed that since Ian has a fifo + reclocker and oscillator, he is designing for use with his boards. Reclocking before the fifo makes little sense to me. Ian's design works well for his system. Anyway Acko has designed exactly what you describe and there is a GB for that. Ian's isolator isolates and isn't concerned about output jitter because he already has a solution to that.
Old 17th January 2013, 10:45 AM   #2139
roender's Avatar
I totally agree with you.
Old 17th January 2013, 09:52 PM   #2140
iancanada is offline iancanada  Canada
iancanada's Avatar
Default Why I2S/DSD isolator is better than a USB isolator for digital audio interface
I can see there are two reasons:
1, Most of the USB isolators we can touch currently are for USB2.0 full speed 12MHz, not for high speed which is 480MHz. In this case, it will degrade the performance of many good USB audio interfaces which were designed optimizing for 480Mhz high speed, especially for higher Fs application as 192KHz and 384Khz.
2, Even when high speed USB isolator becomes popular down the road, I2S/DSD will still be the better solution than the USB isolator. The reason is very clear. Since we have to power the isolated section from DAC side, powering half I2S/DSD isolator comes with much less noise than powering a whole USB interface. The USB interface usually needs a couple of clocks with different frequency running at same time, not only drawing more current, but also introducing much more EMI noise from power supply and ground.
Ian
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
