| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#2111 |
This is a valid question/issue. I feel like I've been beating a dead horse in both threads but a true high class transport needs a 16 bit I2S, ie 32fs, the original standard I2S, not the hack standard phillips came up with for 24-32 bit I2s.
#2112 |
Got some Crystek CCHD-957s. Now i am probably a bit stupid but how does one solder these to Ian's boards without shorting the output pins. Ian's picture does not make it any clearer.
http://www.diyaudio.com/forums/attac...ithadapter.jpg Last edited by analog_sa; 15th January 2013 at 12:51 PM. |
#2113 | |
- I bet Ians generic clocks are better or at least s good./ |
#2114 | |
is choosing a less facetious title...
#2115 |
RollE2k, I'm having trouble following you, but its clearly not going to work. the dual XO bopard doesnt just work as a standalone reclocker for any signal you send to it.
#2116 |
Ok, that was a bummer then. Not even if you isolate the i2s before you send it to the XO-board? you have to run through the fifo?
#2117 | |
#2118 |
But how does the XO-board work then, if it's not only isolated i2s. I know the FIFO buffers the signal and sends to the XO-board, but what difference does the FIFO board have except that it buffers, that makes it impossible to send a isolated i2s into the XO?
I understand that you say it don't work - but my question now is rather why it doesn't work. |
#2119 |
because the clock board is controlled by the fifo main board and its input
its possible you could send it some 48khz audio directly before switching to fool it into staying on 48khz then send it movie data. possible, Ian will have to answer that. but honestly thinking up some mechanical system that may be kludged to work in theory and making something work in reality could easily be very different. Last edited by qusp; 15th January 2013 at 07:04 PM. |
#2120 | |
, but I don't see many alternatives for those frequencies, Ian's generic clocks included. For "hirez" results we need Si570 board. |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1714 | 11th May 2013 03:43 PM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
