Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 2nd January 2013, 04:42 PM   #1811
Julf is offline Julf  Europe
Originally Posted by qusp View Post
OK so perhaps the better way would be to have 2 fifos and shuffle between them as needed.
Not sure that helps in any way - you are still back to the issue of only being able to discard/fill in material in the quiet pauses.
assuming it ever becomes a problem.
Unfortunately it won't suddenly become a problem. Some users (with greater clock frequency mismatch) will occasionally run into it (when playing long, uninterrupted pieces of music), others won't - so it will be hard to replicate/verify the complaints.
I gather on the next version ie multichannel/DSD version, Ian is boosting the memory, so perhaps it will just become even more of a non-issue
More memory will make it more likely that you will stop listening to the music and go to bed before the buffer under/overflows, thus solving the problem
Old 2nd January 2013, 04:52 PM   #1812
Fridrik is offline Fridrik
Hi! if we take the example from Julf a 0.1% difference between source /reclock clocks
Worst case for 44.1Khz:
44100 (sample F)x 32bit (Spdif encaps 16bits) x2 (channel)=2822400 bits/s
half fifo (4M/2) = bits
2048000/2822400 = .73 seconds buffer
.1% error would be 2822 under/over samples /s
the fifo would underrun in 2048000/2822 = 725s = 12 minutes
So since no regulation mecanisme is implemented in the fifo this would leave us with 62 minutes of 'jiterisched' music after 12 minutes ;-)
But +-.5% mean error on frequency precision is normaly seem on clock using a resonnator.
Even a 1000Ppm clock module is +-0.001% ;-) and even then +-0.001% is not a error of +.001% but a error between -0.001% to .001%
Correct me if I'm wrong but I thing we have at least one order of magnative of safety margin event at 384khz.
Old 2nd January 2013, 05:31 PM   #1813
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
...just send back the MCLK to the source..
FIFO buffer will isolate anyway from the source jitter, even with the worst source
no memory underflow/overflow since the source will work with the same master clock.
No PLL needed, 1MB memory is safety enough.
and don't tell me you cannot tweak the source, we are diyers
Old 2nd January 2013, 05:42 PM   #1814
qusp is offline qusp  Australia
qusp's Avatar
yeah this fifo memory is far too linear!
well yes it will 'suddenly' become a problem, because presumably at some point, someone, anyone! will suddenly report actually.... having a problem. until then there is effectively no problems only potential problems. very much like Schrödinger
given ryanj has been using a cheap chinese SD player with fifo and not made a report, i've used it with no less than 5 different sources and even during long jam sessions in Logic audio and internet radio over a period of more than a year...no problem and I gather the worst thing that can happen is it will either have a segment of silence, or will replay a segment.
most people by the time theyve got to the point of buying the fifo, already have a reasonable source
yup =)
Old 2nd January 2013, 05:48 PM   #1815
qusp's Avatar
due to fifo memory buffer it is asyncronous with the source, it has to be, but I suppose it could simply be marching in time, but still offset in time. me, I wont bother doing anything about it or expending any effort or money on the problem that hasnt shown itself
fridrik 1000ppm is 1/1000th or 0.1% but honestly who is using anything like a 1000ppm clock with fifo? most will be using 50ppm so 0.005%
Old 2nd January 2013, 06:11 PM   #1816
vzs is offline vzs  Europe
@Julf
First page fourth post says:
"- Half-full over flow time: 1486 seconds (at 44.1KHz input I2S stream with 500ppm frequency tolerance);"
The most crappy clocks for audio frequencies I could find have +-120ppm tolerance. If your source happens to have one of those and its really on its ppm limit then the FIFO will over/under run in 6181 second (~103 minutes) of continuous play... be serious, even Beethoven's 9th symphony is shorter played in one continuous stream.
If you think a PLL with a VCXO would be a better solution you are wrong since most VCXOs have less pull range: e.g. TentLab's VCXOs have +-100ppm, so those will not even work.
Old 2nd January 2013, 06:24 PM   #1817
qusp's Avatar
that was long before the final version too.
Old 2nd January 2013, 08:30 PM   #1818
aos is offline aos  Canada
I think it should be a reasonable fallback to have the reclocker stop once it detects under or overflow, refill it to half again and continue, providing silence for those few seconds. Preferably providing a LED status indicator as to what happened. I would personally find it a good tradeoff. Adding a VCXO with a PLL trying to pull the frequency average to be the same as the source is the ultimate solution but it has its own issues (how good will the PLL filter be? It needs to have a sub-Hz cutoff and the cutoff needs to be steep enough otherwise we're back at square one with jitter).
What does the FIFO do right now when it hits buffer over or under run?
Old 2nd January 2013, 09:15 PM   #1819
Sorry your correct 0.1% , the exemple was simply to demonstrate the worst case : 500ppm (worst crystal of the 1990) x 2.
100ppm should be the most probable worst case scenario . If I take my computation this would mean :
about 120 minutes = 44.1 mhz
about 14 minutes = 384 mhz
The ways the get under or over buffer are then
1- play long classical musique piece at very high sample rate
2- play a long play list with the gapeless mode ON in your player setting.
to conclude:
For most of us the under of over buffer condiftion is no concern in theory and in practice ;-)
Old 2nd January 2013, 10:01 PM   #1820
iancanada is offline iancanada  Canada
iancanada's Avatar
Originally Posted by vzs View Post
@Julf
Agree.
The worst audio clock I have ever met was from a CDROM, but it still better than 100ppm. Clocks from most of the digital audio sources we are running right now will be better than 30ppm, which including the CD players and many USB sound cards. If they are talking about 50ppm, that means it's over a wide temperature range, says 0-55 degree C. At room temperature, situations will be much better.
So, I'm just wondering what kind of worse digital source we are gonna feed to a FIFO?
There are more than 100 members running the FIFO now, so, maybe they can tell if they have experienced empty/overflow? if so, at what condition, and what was happened. While I did R&D, I can only simulate these cases by a programmable clock generator with running at much higher or much lower frequency.
VCXO can be a kind of solutions if don't care about jitter. VCXO usually comes with bigger jitter than a XO (except very expensive high end VCXO). For example, Si570 is a XO with phase noise -112dBc/Hz at 100Hz, however, Si571 is a VCXO, the phase noise is degraded to -87dBc/Hz at 100Hz. The reason is obvious: the noise on the control voltage will be converted into jitter.
Just a personal point
Ian
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1400 19th December 2017 07:46 AM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
