Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 22nd December 2012, 06:06 PM   #1751
crobbins5421 is offline crobbins5421  United States
Default Battery Supply Question...
Got the boards Ian. Thank you. They look very good.
I'm especially grateful this Christmas that you did "the heavy lifting" and had the resistors on the isolator board pre-soldered....
After reading through the thread and the documentation on the FIFO and Dual XO, I saw where you give a recommendation for battery power for the FIFO. I was wondering...should I choose to not remove the two LDO's on the XO board (implementing the isolator) what would be your recommendation for reasonable LiFePo4 battery power to the XO board?
if I missed that recommendation earlier I apologize.
Old 22nd December 2012, 06:34 PM   #1752
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Hey Ian. I'm working to install the Isolator board. I tested it with double clock board powered by FIFO, and it's working fine. I'm working to power it directly now. According to docs, I removed L11. 44.1 & 88.2 leds light up now, but now I'm not getting lock or sync. I'm digging through the thread, but what am I missing?
Old 22nd December 2012, 07:21 PM   #1753
Can you say Audio?
Nevermind. Started checking v's - the Isolator failed. Must be a cold solder joint. Bypass it, and I'm powering the Dual clock board via J5.
Old 22nd December 2012, 08:24 PM   #1754
Can you say Audio?
Heh. Just read up to 172 where this was asked. Sorry for the noise.
Old 23rd December 2012, 03:44 AM   #1755
iancanada is offline iancanada  Canada
iancanada's Avatar
MisterRogers, everything is good now? Please let us know your solutions again, others may meet same problem.
Have a nice holiday.
Ian
Old 23rd December 2012, 05:44 PM   #1756
Blitz is offline Blitz  Germany
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
5. AR2 - definitely!
6. wktk_smile
7. hirez69
8. CeeVee - you bet!
9. number9
10. analog_sa - GB maniac
11. edbk
12. atom6422
13. misterrogers X2 - Of Course!
14. NicMac - as usual!
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
23. Greg Stewart (also of course!)
24. Vitalica
25. spm
26. Fridrik
27. ccliu
28. makumba1966
29. lindamar
30. Finaxe
31. Odysseas x2
32. palmito
33. crazikid
34. deanoUK
35. Julf
36. DUC985
37. rsotirov
38. kvl
39. bkdog
40. necplusultra
41. Nikola Krivorov X2
42. nvduybom
43. Popolvar
44. TNT
45. TUBO
46. Blitz
Old 23rd December 2012, 07:53 PM   #1757
Can you say Audio?
Hey Ian - thanks for the followup. I removed the Isolator and all was well, so it's clear I have an issue there. It worked fine, so I suspect a cold join. That's on my chore list for this afternoon - I love having a break, with plenty of time to play :-)
Also, I build a couple TPS7A4700's at 3.5v this morning for use as AVCC regs in my BIII. Interesting :-) Not sure what I expected; I'm running Paul Hynes there so it's already pretty damn good. Just a short listen - seems to have a touch more bottom end clarity and more high end sparkle. Thoughts on what to expect?
Old 23rd December 2012, 11:53 PM   #1758
Adrculda is offline Adrculda  Canada
Send a message via MSN to Adrculda Send a message via Yahoo to Adrculda
I'd get on the "Band Wagon" as soon as that multichannel unit becomes reality :P
SMPS Tests Soon ??
Adrian
Old 24th December 2012, 01:01 AM   #1759
qusp is offline qusp  Australia
qusp's Avatar
I really dont think that many of us are interested in SMPS for one of the more vital analogue sections, i'm certainly not and I dont mind them elsewhere. the fifo doesnt use much current really, so linear or shunt low noise regulators are pretty easy to implement, I see no need to push for SMPS
@ MisterRogers:
the Paul Hynes regs are superior, maybe even by an order of magnitude, but certainly significantly
Old 24th December 2012, 01:49 AM   #1760
Can you say Audio?
Yep - more listening has born that out. :-)
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
