| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1721 | |
Oh, That's not a special issue, just for eliminating the possible loop, otherwise the surrounding EMI noise will generate current within as an antenna. Actually all the mounting holes should be connected to the metal case to keep the noise as low as possible, and not to be 'island' at same time. Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#1722 |
Thanks Ian
![]() I know its not a particularly critical issue for the device's performance, I just was curious to learn the reasoning, because like you say they're each attached to the enclosure and it was just something that I hadn't noticed before. It seemed as though you'd gone out of your way to do it intentionally so I thought I'd ask since your designs tend to not do things without a good reason! Chris |
#1723 | |
.Ian
#1724 |
Can you say Audio?
Ordering parts for the TPS7A4700 boards; What should I order for D1 (LED)? R9 can be pretty much any 1K 1206, right? Thanks in advance for your help :-)
#1725 | |
For TPS7A4700 reg PCB, package of both LED D1 and R9 is 0603. Yes for red yellow or green, R9 can be 1K with 3.3V output. But if you want blue or white LEDs, you have to make sure the Vf is less than 3V, and R9 may also be reduced. Anyway, D1 and R9 are just for power indication. You can keep them un-assembled if you don’t need them .Ian
#1726 |
Greetings,
I finaly tried out the isloator board but I cannot seem to have a lock on the input. I verified shorts on the resistor array and they checked out good with no shorts. I don't know where to go from here. any help appreciated. thanks |
#1727 |
MY BAD.
I think with the isolator in circuit, the clock has to be powered externally. I could not find instructions on accomplishing this except something about removing L11 Are there any pads and what voltage is expected? |
#1728 | |
Please check not only the short, but also disconnect. The resistor is 33ohm. Please reference the schematics I posted. Also confirm the part number of isolator is correct. Good luck. Ian
#1729 | |
Ian
#1730 | |
. I attach it again, please see the last page.Good luck Ian
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1714 | 11th May 2013 03:43 PM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
