| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1681 | |
is choosing a less facetious title...
this is IMO more important than catering for inrush current in other applications actually i'll modify that, its more important to me for my objectives, you have your prerogatives. Last edited by qusp; 14th December 2012 at 04:36 PM. Reason: added non =) got rid of wrong/rude sounding phrasing |
#1682 |
on the other hand it should be an easy enough mod to add, using one of te optional connectors to tap/sense the voltage
#1683 | |
Lets first clarify the situation that you're concerned about. The battery management board in its current design assumes that the device will be turned off while the batteries are not fully discharged. What about when someone walks away without turning it off and the batteries are allowed to continue to drain for an unknown period of time. Is that the situation that you're concerned about? I don't see a reliable way to sense voltage and trigger the relay for shut down without active devices. An under voltage threshold set by comparator and a logic gate would be what I'd add off board but it would no longer be passive... |
#1684 |
No matter it is added off board or included in the battery management board, it is a must have function for battery operated devices.
#1685 |
Contributor
As an aside, could we run a dropper resistor and led, giving visual confirmation of suitable voltage, run an LDR after the led to keep the "active" devices to of the loop. Or will the noise of the led's be adding noise to the power supply, though at dc it will be a constant current? If we then monitor the LDR resistance to switch off ad charge, is this not a wimpish way to do it? Not the most accurate for sure, but a simplistic method?
Just a thought. |
#1686 |
Contributor
The LDR being a separate device of course but in series using the same current as the visual led.
You can probably tell I'm not an electronics genius..... |
#1687 | |
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#1688 | ||
This question is connected to battery protection issue. Actually any lithium battery has a small protection board inside the battery pack. The protection board provides both over charge and over discharge protection by switching the MOSFET. However, my concern is any passive components will introduce noise .... Ian
#1689 | |
noise or short the ground is a question. Ian
#1690 |
it will require working with the dual clock or fifo board signals I guess if you must have it disconnected at all times during audio. but i'll need to think some more on a more automatic plan. it will likely utilize a couple transistors, so not completely passive.
most lipo batteries with protection create more of a noise issue that any protection circuitry we might design, my A123 have nothing, any OEM bought cells usually wont either. A123 wont explode or catch fire when fully depleted, they just can get damaged, but some lipo may have pretty serious issues Last edited by qusp; 15th December 2012 at 03:38 AM. |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1715 | Today 08:15 AM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
