| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1671 |
#1672 | |
BTW, if some folks was interested, we could do a group buy, at least 5 people for any frequency. At this time I'm building a quiet regulator to supply the OCXO and compare it with other options such as Crystek, Tentlabs and my own design based on Laptech high performance AT-cut crystal. I'll let you know the sonic results. Lab tests speak for themselves. |
#1673 |
Can you say Audio?
I might be interested in joining a GB for this; if cost/performance is good.
#1674 | |
I'm looking forward to hearing your result. Regards, Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#1675 |
1. I understand the application of the passive battery manage board may not be limited to powering the clock board. To avoid any damage by the power on surge current of charging big capacitors, I include an optional delayed relay to limit the possible high surge current. Even for a clock board, the surge current may still go high if there are some low ESR capacitors on board. The delay time now is 0.5s, but it’s adjustable.
2. Remove some options on V1.0 which may not be used for normal configuration. That makes it easier to setup, clean and less confusion. 3. To make it easier setting up battery arrays, I placed the battery and charger connectors on one side and the output and control voltage connectors on the other side. Stack on top of each other is also available. All physical dimensions keep same no change. Hopefully this passive battery management board V2.0 will be available together with the Si570 clock board. Please let me know for any suggestion and comment. Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 Last edited by iancanada; 14th December 2012 at 01:03 AM. |
#1676 |
Master Burner
Ian,
If only clock board is powered by batteries and delayed, is it possible for that to be the problem? Usually clock is the one that has to be powered up first before any other digital circuits? I think I recall info that DAC could have a problem if it powers up before the master clock?
www.burningamp.com |
#1677 | |
You are right, the clock should be running priori to all other section of the system before the gone of the reset signal. However, the delayed realy will not delay the power up, it just limits the high surge current for a very short of time (the main realy already switched on). So, I don't think it will cause problem on the start up time of clock board. But I'll double check and make some real measurements on the power on time of the clock board after I get the PCB prototype. The delayed realy is just an option, if the main relay can handle the surge current, then you may not need the delayed one. But for high current application such as powering a DAC analog power, the dealyed relay will help. Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 Last edited by iancanada; 14th December 2012 at 01:07 AM. |
#1678 |
Ian
As a battery management, should it automatically cut off the battery to prevent over discharge? |
#1679 | |
Ian
#1680 | |
Master Burner
AR2
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1718 | Today 12:01 AM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
