Go Back   Home > Forums > Source & Line > Digital Line Level
Old 7th December 2012, 06:32 PM   #1641
Forgot to mention passive battery management board has been tested and works great in standard configuration. Thanks Ian!
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 7th December 2012, 07:00 PM   #1642
Originally Posted by qusp View Post
fridrik, i'm not sure these regulators are that suitable for an IV stage, LDOs in priciple and across the board generally rely heavily on their output capacitors to provide for transient current demands ie. their transient response is directly proportional to the output capacitance; by themselves while the noise is good and low, the transient response is usually pretty ordinary.
this is fine for things that have low, or stable current demands that can be supplied by lowZ decoupling at point of load, but IV stages though not having huge current demand (most of them), do have transient current demands that may be enough to deplete local decoupling.
what do you think Ian?
Thanks for your comment qups. I will take this in consideration, But be aware that I'm trying to remplace a LM337T-ND of the original design which is also supposed to be some kind of LDO ;-)
For the moment I will just use the TPS7A4700 to power the FIFO and the SPDIF adapter. Ian do you suggest 2 LDO board to power Fifo+SPDIF ?
Old 7th December 2012, 11:53 PM   #1643
iancanada's Avatar
Default TPS7A4700 PCB run out
I'm afraid I run out all of the TPS7A4700 PCB. Thank you so much for your very kind donations. I appreciate!
Will combine the shipment for those who has a GBIII order number. PCB shipped today to all of those without a GBIII order number.
Pretty sure I'll supply this PCB again with the Si570 board.
Thanks again
My best regards.
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 7th December 2012, 11:54 PM   #1644
iancanada's Avatar
Hi TheShaman,
Good to know that, you did great job! board looks nice, good picture.
Please let me know if you need any support.
Ian
Old 8th December 2012, 12:00 AM   #1645
iancanada's Avatar
Although 4700 has very low noise density, but it optimized to VCO/XO/RF power supply with very good high frequency performance and can drive low ESR MLCC output capacitors. I still think a well designed shunt reg is better for a I/V. But I might be wrong. Hope somebody can give 4700 a try for analog applications.
Ian
Old 8th December 2012, 12:27 AM   #1646
qusp is online now qusp  Australia
is choosing a less facetious title...
qusp's Avatar
if you look at te step response it confirms what i'm saying and the psrr could be better too (-60 -70dB through the audio frequency range), better than any other LDO i've seen however. its perfectly suitable for how you are using it Ian, it has amazingly low noise, but its not really the thing supplying the load current in your designs, its supplying the capacitors which are supplying the load, so the caps are/should be chosen with this in mind
have you exposed the sense pin on your PCB Ian? or have you just tied it to the output voltage?
nvm i'll look at your schematic....
Old 8th December 2012, 12:55 AM   #1647
iancanada's Avatar
Agree. I have been trying different caps for it in the past weeks. It seems MLCC plays batter then TAN, through it's more sensitive to mechanical vibration. But which MLCC is the best? I'm still wondering and looking for.
Of course, the sense line should always be independent from the output
Ian
Old 8th December 2012, 01:40 AM   #1648
qusp's Avatar
many designs, particularly if the reg is on the same board just tie it directly to the output to save trouble and assuming that there will not be significant voltage drop over a short trace, but external designs like yours that can and will have unknown loads its better to have it available, so glad you did also its pretty unique in that most adjustable regulators do not have a sense pin, because the pin that is usually used for sense is changed for an ADJ pin, sensing the voltage across the setting resistors. As a result its often only fixed voltage LDOs that have a sense pin.
as for Caps, I would use a mix of Panasonic SP-CAP (SX variant) (I use these whenever I can, Acko uses them too, great caps) and MLCC and I mightve looked at using some AVX Accu-P thin film caps for the HF Si570 decoupling directly on the pins
Old 8th December 2012, 02:28 AM   #1649
I've been wondering if one of those tiny cap arrays would be useful for Si570 decoupling ...
DK - 490-3446-1-ND (only rated for 6.3V) - GNM314R70J105MA01L Murata Electronics North America | 490-3446-1-ND | DigiKey
Some datasheets - http://search.murata.co.jp/Ceramy/im...70J105MA01.pdf
http://www.mouser.com/catalog/specsh...M%20Series.pdf
An AVX version - http://www.avx.com/docs/Catalogs/w2lw3l.pdf
Old 8th December 2012, 02:56 AM   #1650
iancanada's Avatar
Good ideas. Based on my testing result, capacitors are very very important for a clock power supply.
Ian
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1800 Yesterday 07:55 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1306 9th June 2013 10:09 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
