Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1611 | |
![]() It's a LeCroy digital osc with 1GHz bandwidth and 8GHz sample rate. Ian
gitHub:https://github.com/iancanada/DocumentDownload GB2017:http://www.diyaudio.com/forums/group...ml#post5111232 Last edited by iancanada; 4th December 2012 at 02:39 AM. |
#1612 |
Ian, is it just me, or does the inverted MCLK show more ringing than normal phase? is this ringing from your probe not being properly terminated or is this potato logic the unterminated driver you mentioned you would place?
secret? hmmm what secret? |
#1613 |
but I have to say with the inverted MCK if we visualize without the ringing, which we can presume is an artifact or the termination of the probe; the wave does look cleaner. in normal MCLK the down stroke looks a bit different to the upstroke, with the inverted MCK it seems to exhibit a more similar shape on the up and down.
#1614 | |
Can you observe any significant differences in the profiles? |
#1615 | |
![]() Ian
gitHub:https://github.com/iancanada/DocumentDownload GB2017:http://www.diyaudio.com/forums/group...ml#post5111232 |
#1616 |
Master Burner
You see, and guys with AP will say I wish I have LeCroy, hahaha.
![]() Does your scope has FFT feature? It might be manual process, but with good signal generator, you might be able to record and than read various Fqs.
www.burningamp.com |
#1617 |
I fear the problem he'll encounter is the depth of the noise floor =)
#1618 |
I'm still waiting for qusp to buy an AP so I can borrow it
#1619 |
Me too
![]() Ian
#1620 | |
![]() Ian
gitHub:https://github.com/iancanada/DocumentDownload GB2017:http://www.diyaudio.com/forums/group...ml#post5111232 Last edited by iancanada; 5th December 2012 at 12:39 AM. |
Thread | Thread Starter | Forum | Replies | Last Post |
XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Line Level | 3175 | 1st April 2018 04:24 PM |
exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1400 | 19th December 2017 07:46 AM |
DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
New To Site? | Need Help? |
