| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1561 |
is choosing a less facetious title...
i2s fifo buffer (finished and available)
spdif board (finished and available) dual clock board (finished and available) battery management board (finished and available) isolator board (next GB I think) Si570 multi frequency Clock board (nearing end of development, ready for next GB I think) PCM daughterboard and level-shifter for NOS dacs (nearing end of development, but not yet available) u.fl adapters (available) Clock adapters (available) |
#1562 |
Si570 interest list:
1. bigpandahk 2. tagheuer 3. hochopeper 4. qusp (of course) 5. AR2 - definitely! 6. wktk_smile 7. hirez69 8. CeeVee - you bet! 9. number9 10. analog_sa - GB maniac 11. edbk 12. atom6422 13. misterrogers X2 - Of Course! 14. NicMac - as usual! 15. Zoran 16. PET-240 17. Coolhead 18. Slartibartfasst 19. SYklab 20. Regland 21. Neb001 22. SPWONG 23. Greg Stewart (also of course!) 24. Vitalica 25. spm 26. Fridrik 27. ccliu 28. makumba1966 29. lindamar 30. Finaxe 31. Odysseas x2 32. palmito 33. crazikid 34. deanoUK 35. Julf 36. DUC985 37. rsotirov 38. kvl 39. bkdog 40. necplusultra 41. Nikola Krivorov X2 42. nvduybom 43. Popolvar |
#1563 |
Hi, Just to say your are no fun guys ;-). you are working to fast and specialy Ian
Preparing for the arrival of my Fifo I was shopping for a nice LDO regulator to replace a LM7805 and a LM2937ET-3.3 on my DUAL Mono PCM1794A DAC board. Browsing on the TI site I saw the TPS7A4700 LDO what a nice chip: good specs (1A), simple design but wait I saw it somewhere before .... hum Oh no not in the fifo thread ;-) Ian any chances your include the TPS7A4700 PCB in GB4 ? So back in lazy mode for now ;-) Last edited by Fridrik; 25th November 2012 at 07:49 PM. |
#1564 | |
TPS7A4700 reg board is under evaluation now. I'll include it in GBIV if I'm satisfactory with it. Thanks, Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#1565 |
glt mentioned that inversed mclk would be better for ESS8018 running at sync mode. I read the ESS application note, it really make sense.
I think we need include this feature into the Si570 clock board Ver3.0. Here I attached the waveform of I2S with normal MCLK and inversed MCLK. The difference on timing in between is very clear. I’ll do some real measurement on this issue later on. Ian
#1566 |
Hi Ian,
Although I may be wrongly getting the credit for "mentioning it", I don't understand what you are implying regarding the timing "making sense". could you explain? And thanks for moving the state of the art forward and benefiting us in the process...
www.hifiduino.wordpress.com |
#1567 | ||
Ian
#1568 | |
.Ian
#1569 |
yeah ha look I dunno, I know I asked for it ages ago by email or one of the threads (in May'ish), probably lost in the noise, but I was only parroting it from the datasheet and the Japanese crew so honestly its not really something I should get credit for either. Acko is playing with it also afaik and I have that option on titan, which was also initially designed for an ESS
#1570 | |
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1798 | Yesterday 08:44 PM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1306 | 9th June 2013 10:09 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
