Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd November 2012, 10:30 AM   #1401
Hey mate,
Check Ian's post here.
You only need the parts listed under the "Standard Configuration" headline (on the 3rd pic).
It's just 7 components if you exclude the headers.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 3rd November 2012, 02:31 PM   #1402
iancanada's Avatar
Originally Posted by TheShaman View Post
Hey mate,
Thakns TheShaman, but I might be a little mistake on the BOM. R10 should be 0 ohm for the standard configuration .
Originally Posted by coolhead View Post
Ian, it Looks beautiful.
I couldn't keep up with your update, I think that is a good sign for lazy people like me to keep reading.
I received your power management board, I just want to confirm the resistors to make sure I didn't do a silly mistake:
1. R1, 2, 5, 6, 8, 10 are 0ohm
2. R11 is 100ohm
3. R3, 4, 7, 9 are 1kohm
4. R12, 13 are short because my -ve is Gnd
Thanks.
coolhead, for standard configuration,
1. R1, 8, 10 are 0ohm
2. F2 fuse or just short
3. R9 is 1kohm
4. D3 LED
5. D4 4148 or any diode for coil flayback
please refer to the below picture, just add with R10 (0 ohm)
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 3rd November 2012, 03:04 PM   #1403
3. R9 is 1kohm
4. D3 LED
Ian
It is much clearer now. Thanks Ian.
Old 4th November 2012, 04:25 AM   #1404
Ian I've had a read of the si8605 datasheet, but just want to tripple check, the si8605 could also be used to isolate a GPIO from a microcontroller using on of the unidirectional channels right? I haven't got a i2c control interface on my dac, but I do have a pin that can be pulled low to mute the dac. I am thinking that I could use Si8605 for Si570 serial and this mute pin control.
Old 4th November 2012, 11:57 AM   #1405
Default Fifo compatibility with CS8416 and PCM1794A, 24bits, DA Converter
Hi! The second lot of the second group buy is almost closed and I would like to know if placing the fifo between a CS8416 and two PCM 1794A in dual mono configuration could be a problem? Ian? The PCM1794A use a standard 3 wires left jutified I2S protocole... Thanks Fred
Old 4th November 2012, 12:12 PM   #1406
Si570 interest list: 1. bigpandahk 2. tagheuer 3. hochopeper 4. qusp (of course) 5. AR2 - definitely! 6. wktk_smile 7. hirez69 8. CeeVee - you bet! 9. number9 10. analog_sa - GB maniac 11. edbk 12. atom6422 13. misterrogers - Of Course! 14. NicMac - as usual! 15. Zoran 16. PET-240 17. Coolhead 18. Slartibartfasst 19. SYklab 20. Regland 21. Neb001 22. SPWONG 23. Greg Stewart (also of course!) 24. Vitalica 25. spm 26. Fridrik
Old 4th November 2012, 01:26 PM   #1407
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
do you think we could have more of a list? what happened to the formatting? you posting from a phone or something fridrik?
fridrik, why would you use the CS8416? sure it'll work, but at the low price of the spdif module I would just recommend getting that, as a system it all works well. afaik with the latest firmware the fifo allows i2s, PCM, Left justified
I dont know the PCM1794 all that well, it depends on how its dual mono mode works, is it actually sent a discrete left and right channel i2s stream, or does it work like es9018/12 and when set to mono mode the dac is given an address to identify itself as the left or right channel, then both are sent the same stereo stream, but the left channel dac knows to use only the left channel information and vice versa for the right channel dac?
if it needs the i2s to be split into left and right mono streams then no the fifo wont work
Old 4th November 2012, 01:27 PM   #1408
qusp's Avatar
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
7. hirez69
9. number9
11. edbk
12. atom6422
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
24. Vitalica
25. spm
26. Fridrik
Old 4th November 2012, 01:30 PM   #1409
iancanada's Avatar
Yes, correct. Si86056 has both I2C isolator and GPIO isolator. The GPIO is bidirectional. So, it's very easy use for serial communication port (USART, or LVTTL RS232).
Ian
Old 4th November 2012, 02:57 PM   #1410
Formating was removed because au noscript in firefox...
Yes your first decription is rigth the I2S signals are connected strait from the CS8416 output to the 2 PCM1794 (left and right ) inputs.
The only two problem I could see are :
1- Is the fifo output able to drive 2 inputs ( probably)
2- The protocol configuration of the PCM1794 : I2S or standard 24 bit right justified
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1798 Yesterday 08:44 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1306 9th June 2013 10:09 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
