Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 24th October 2012, 01:11 AM   #1321
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by iancanada View Post
Yes, you should. You may try to place the I2C isolator at the empty space. You can source it from digikey.
Ian
Ian
Please advise the digikey part no. for the 2 pins plug and socket for power connection on clock board.
Old 24th October 2012, 01:19 AM   #1322
qusp is offline qusp  Australia
qusp's Avatar
These wouldnt drop below 3.45 till about 1/2 way through their charge, sits on 3.50->3.40 for ages and at ~90% discharge they are still sitting about 3.2. Mine wouldnt drop off that steeply under a 10A load.
they might be lifepo4, but probably not Nanophosphate. what are you using to cut off the voltage, till the battery board is ready that is? could you have damaged them with repeated deep discharge, or have they always been like that?
Old 24th October 2012, 01:20 AM   #1323
qusp's Avatar
JST XH I think
Old 24th October 2012, 01:21 AM   #1324
hochopeper is offline hochopeper  Australia
Originally Posted by bigpandahk View Post
Ian
They are 2pin JST PH series, I believe, 455-1734-1-ND - I don't have the connector in hand or a clock board so I could be wrong, but if in doubt, check the BOM for the battery board, I think Ian would have used the same connectors there.
Old 24th October 2012, 01:30 AM   #1325
As I still testing my setup, haven't considered the cut off yet. The batteries are new and have been recharged less than 10 times. Only been deep discharged twice.
Waiting for Ian's battery board to safe my life again
Old 24th October 2012, 01:47 AM   #1326
Thanks hochopeper. Found them in Digikey.
Old 24th October 2012, 02:13 AM   #1327
I'd get Ian to confirm that, it's just an educated guess. I went and checked the BOM for the battery monitor board and it is a through hole version, so not the same as I had first thought.
Old 24th October 2012, 02:23 AM   #1328
iancanada is offline iancanada  Canada
iancanada's Avatar
Thanks hochopeper, for the P/N of SMD version,
455-1165-ND
455-1127-2-ND
455-1704-ND
Ian
Old 24th October 2012, 09:08 AM   #1329
qusp's Avatar
As I said you can make it. Did your hand survive from the hot air .
I like the isolator board, it makes the grounding design much easier for a DAC to get rid of ground loop. The clock should always be treated as an analog part for a DAC. The isolator board makes them together.
Ian
I guess i'll take that bow now
lol
Old 24th October 2012, 09:52 AM   #1330
was a good suggestion mate!
I want to know what bigpandahk has planned now he's the only guy apart from Ian with more than one of those isol boards!
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
