Go Back   Home > Forums > Source & Line > Digital Line Level
Old 23rd October 2012, 02:19 AM   #1311
Originally Posted by iancanada View Post
All passive battery manage board PCB posted today for evaluation. Hope testing group will get them soon.
bigpandahk: Just sent a new isolator PCB together, four resistor arrays assembled. Hope it works.
Ian
Ian
You are GREAT. THANKS VERY MUCH.
I am still trying hard to assemble the resistor arrays correctly.
Old 23rd October 2012, 07:24 AM   #1312
Followed Ian's procedures and with the help of microscope, I finally soldered the resistor arrays without any short. The isolator board is working now and sound GREAT.
With the board, I can clearly hear a much better bass. Will report again after run-in.
Old 23rd October 2012, 07:45 AM   #1313
Great news! Look forward to hearing more reports on how these go
Old 23rd October 2012, 07:46 AM   #1314
hirez69 is offline hirez69  Europe
hirez69:
The max input DC is rated at 5.5V. Could go a bit higher based on real testing, because of output current is much lower then 200ma for each LDO. But not recommend higher than 6.5V
Ian
Thank you.
I own a 6.6V LiFePO4 battery, but I think it's better not to use it.
Old 23rd October 2012, 08:36 AM   #1315
Originally Posted by hirez69 View Post
Thank you.
I am also using LiFEPO4 battery without any problem with both clock and FIFO. 6.6V is only when the battery is fully charged and will drop below 6.5V in very short time.
Old 23rd October 2012, 09:53 PM   #1316
iancanada's Avatar
As I said you can make it. Did your hand survive from the hot air .
I like the isolator board, it makes the grounding design much easier for a DAC to get rid of ground loop. The clock should always be treated as an analog part for a DAC. The isolator board makes them together.
Ian
Ian - FIFO KIT & Si570 Clock Board GBIV
http://www.diyaudio.com/forums/group...ml#post3372684
Old 23rd October 2012, 10:50 PM   #1317
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
no thats incorrect, at least for any legit A123 ive had/have, 3v3 is the nominal LiFePO4 chemistry voltage; fully charged is up to 3v65 so 2 in series like you have is 7.3V!! then they usually drop to around 3v45 (6v9) pretty quickly and spend about 80% or more of their time slowly going down to 3v25 per cell and then drop pretty quickly to 2v9-3v. the vast majority is of that is spent well ABOVE 3v3/6v6
Old 23rd October 2012, 10:59 PM   #1318
Ian
Yes, the board is a great design, I will use the additional isolator for I2C and see if there is any further improvement.
Old 23rd October 2012, 11:27 PM   #1319
iancanada's Avatar
Yes, you should. You may try to place the I2C isolator at the empty space. You can source it from digikey.
Ian
Old 24th October 2012, 01:00 AM   #1320
I am using China made "LiFEPO4", can't proof if it is real "LiFePO4" fully charged voltage is 7.2V, 3.4 is the highest voltage removed from charger and drop quickly below 3.3. Two battery can power the clock + FIFO + SPDIF for more than 18 hours.
XMOS-based Asynchronous USB to I2S interface Lorien Digital Source 1791 Yesterday 09:13 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1306 9th June 2013 10:09 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
