Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 21st October 2012, 05:46 PM   #1301
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Originally Posted by AR2 View Post
Guys, I have not seen the position and size of those resistor arrays, but what you might find helpful is if you cannot solder the regular way, what sometimes works is to apply solder paste to the pads (very thin layer) and than heat up with hot air, while you are holding resistor pressed from above. If you do not have SMD workstation, you could use heat gun, if it is the one with temperature adjustment. Obviously SMD station will be better, but if you do not have it, heat gun will do the job. You have to be careful not to apply too much of the paste, so the trick is to apply paste and takeaway with cotton swab. What is left is quite enough.
OK, I just checked picture. What you have to have is really fine braided wick. So even if your solder connects resistor legs, do not worry, you will take it easily with wick. But the key is to have the finest wick, and if you are using solder use the thinnest one you could find.
www.burningamp.com
Old 21st October 2012, 05:50 PM   #1302
vitalica is offline vitalica  Europe
Si570 interest list:
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
5. AR2 - definitely!
6. wktk_smile
7. hirez69
8. CeeVee - you bet!
9. number9
10. analog_sa - GB maniac
11. edbk
12. atom6422
13. misterrogers - Of Course!
14. NicMac - as usual!
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
23. Greg Stewart (also of course!)
24. Vitalica
Old 21st October 2012, 11:27 PM   #1303
iancanada is offline iancanada  Canada
iancanada's Avatar
Thanks guys, you make a lot of sense on SMT soldering skills.
I'd like to share the way I solder the resistor array, may not the best way, but it works.
1. Heat the pads by hot air to roughly 80C, plate very thin solder to each pad by iron with needle head, I use 0.4mm solder wire.
2. File the pads having thick solder by a small fine file or sand paper and making them flat, clean left metal powder completely by PCB wash cleaner or alcohol.
3. Place flux (clean free prefer) on both the pads and the resistor array.
4. Heat the pads by hot air from SMT solder station till the solder on the pads get melt, meanwhile, pick up the resistor array on the long side with a tweezers, place the resistor array accurately over the footprint with solder melting. Remove hot air but don't move the tweezers to keep the resistor array at the position till the solder curdle. (have to wear glove on the hand holding tweezers, avoid un-stable hand under hot air)
5. Place a bit flux on the pins of the resistor array which is already on the pads, heat it by hot air from the SMT station again and making the solder melt on each pads, the tension of the melt solder from each pad will draw the resistor array into the center balanced position. Use the pin of the tweezers touch a little bit if not exactly at the center, remove hot air
6. Clean PCB again and make sure no any short or disconnect on each pin by a multi-meter.
7. Cross your fingers.
Ian
Old 22nd October 2012, 01:23 AM   #1304
bigpandahk is offline bigpandahk  Hong Kong
Very detailed procedures, Thanks Ian.
But I have un-stable hand even under cool air
Old 22nd October 2012, 02:27 AM   #1305
iancanada's Avatar
Me too . But try to find some support under your hand, that helps.
Ian
Old 22nd October 2012, 02:34 AM   #1306
hochopeper is offline hochopeper  Australia
I haven't tried this for soldering before, but when I was doing a lot of photography a while back I found I could reduce camera shake by keeping both elbows closer to my sides rather than up in the air away from my body ... just a thought.
EDIT: apologies for any embarassement if you're now sitting there waving your elbows like a chicken working this out I'm hoping nobody noticed my sitting at my desk eating lunch and doing exactly that just now!
Old 22nd October 2012, 02:41 AM   #1307
qusp is offline qusp  Australia
qusp's Avatar
lol gimp soldering haha
Old 22nd October 2012, 02:15 PM   #1308
hirez69 is offline hirez69  Europe
Default Isolation board
Ian,
which is the max input voltage for the Dual XO board (J5 connector)?
hirez69
Old 22nd October 2012, 03:01 PM   #1309
iancanada's Avatar
hirez69:
The max input DC is rated at 5.5V. Could go a bit higher based on real testing, because of output current is much lower then 200ma for each LDO. But not recommend higher than 6.5V
Ian
Old 23rd October 2012, 12:39 AM   #1310
iancanada's Avatar
Default Battery PCB shipped
All passive battery manage board PCB posted today for evaluation. Hope testing group will get them soon.
bigpandahk: Just sent a new isolator PCB together, four resistor arrays assembled. Hope it works.
ryanj: still not get your shipping address. Please send me an email, or let me know if your don't need the PCB.
Ian
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1406 4th June 2018 01:47 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3175 1st April 2018 04:24 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
