Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 19th October 2012, 11:55 AM   #1231
ed linssen is offline ed linssen  Netherlands
1. qusp
2. bigpandahk
3. SPWONG
4. NicMac
5. Coolhead
6. Cracra
7. ryanj
8. TheShaman
9. Misterrogers
10.ed linssen
Old 19th October 2012, 01:26 PM   #1232
syklab is offline syklab  United States
Si570 interest list:
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
5. AR2 - definitely!
6. wktk_smile
7. hirez69
8. CeeVee - you bet!
9. number9
10. analog_sa - GB maniac
11. edbk
12. atom6422
13. misterrogers - Of Course!
14. NicMac - as usual!
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
Old 19th October 2012, 03:03 PM   #1233
Regland is offline Regland  Canada
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
7. hirez69
9. number9
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
Old 19th October 2012, 03:09 PM   #1234
glt is offline glt  United States
Originally Posted by analog_sa View Post
Finally put together a test bed: a modified exaU2I via I2S FIFO to Buf 3. As the EXA already has a FIFO and i feed its onboard clocks from a separate regulator, it is not a likely candidate to benefit from the FIFO board.
Could you show a picture of your FIFO implementation?
Thanks.
www.hifiduino.wordpress.com
Old 19th October 2012, 03:17 PM   #1235
qusp is offline qusp  Australia
qusp's Avatar
I would be very surprised if EXA approached the levels of jitter possible with fifo, the clocks do not directly feed the output MCLK with EXA afaik, at least last time I looked (some time ago now) it didnt
confirmed, it still doesnt, the clock clocks the FPGA, which outputs the i2s through the GMRs, so thats 2 layers of additive jitter after the clock, pretty different situation to what we have here
Old 19th October 2012, 04:52 PM   #1236
neb001 is offline neb001  United States
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
7. hirez69
9. number9
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
Old 19th October 2012, 05:02 PM   #1237
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Agreed, it's the reason i asked about the clocks. Have you been able to compare the supplied clocks to the Crystek. Is the audible difference dramatic?
Old 19th October 2012, 05:18 PM   #1238
Here is a suggestion for the production Si570 board:
There has been some discussion of using a phase inverted master clock with the Sabre DAC. The Si570 has a Clk+ and Clk- output. One idea is to have both outputs for manual switching.
I don't know how this would make any improvements but it is a positive tweak that has been discussed.
Old 20th October 2012, 01:04 AM   #1239
iancanada is offline iancanada  Canada
iancanada's Avatar
Hi glt,
I use Potato logic FFs on the 570 clock board. The Tpd=2ns. So, all of the I2S signals will be delayed 2ns after raising edge of MCLK. If feed reversed MCLK into ESS9018, take 98.xxx Mhz, the I2S delay will be 5.1+2=7.2ns, that's the only difference. Using slower HC FFs will get the same thing.
Is there any details about reversing 9018 MCLK?
Nice weekend.
Ian
Old 20th October 2012, 01:36 AM   #1240
SPWONG is offline SPWONG  Hong Kong
1. bigpandahk
2. tagheuer
3. hochopeper
4. qusp (of course)
6. wktk_smile
7. hirez69
9. number9
11. edbk
12. atom6422
15. Zoran
16. PET-240
17. Coolhead
18. Slartibartfasst
19. SYklab
20. Regland
21. Neb001
22. SPWONG
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3172 Yesterday 11:26 AM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1400 19th December 2017 08:46 AM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 01:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 05:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 10:22 AM
