| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#1191 |
Si570 interest list:
1. bigpandahk 2. tagheuer 3. hochopeper 4. qusp (of course) 5. AR2 - definitely! 6. wktk_smile 7. hirez69 8. CeeVee - you bet! 9. number9 10. analog_sa - GB maniac 11. edbk |
#1192 |
1. bigpandahk 2. tagheuer 3. hochopeper 4. qusp (of course) 5. AR2 - definitely! 6. wktk_smile 7. hirez69 8. CeeVee - you bet! 9. number9 10. analog_sa - GB maniac 11. edbk 12. atom6422 |
#1193 |
Can you say Audio?
1. bigpandahk 2. tagheuer 3. hochopeper 4. qusp (of course) 5. AR2 - definitely! 6. wktk_smile 7. hirez69 8. CeeVee - you bet! 9. number9 10. analog_sa - GB maniac 11. edbk 12. atom6422 13. misterrogers - Of Course! |
#1194 | |
.Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 |
#1195 |
The biggest challenge to the Si570 clock board project is the power supply. Silabs declared that Si570 has high PSRR performance and not that sensitive to the supply noise, but trust me, that’s not true. It needs more than 100mA power consumption, much bigger than normal XO oscillators. Although ADP151 is rated at 200mA output, but it really can’t keep good low noise performance at this current level.
Using a 3.2V LiFePO4 battery cell (together with the management board) powering si570 directly is a good solution, which I’m running right now. It works fine and sounds great. The only problem is that the output voltage of the battery is not fixed. During the whole discharge progress, voltage will keep dropping from 3.4V to 3.0V. Actually that’s not bad for a battery, but the interesting thing is, si570 has a sweet point on power supply voltage. It will take around half hour to make the battery running into that point and then Si570 becomes more and more sweet. TPS7A4700 seems to be one of the best alternatives. It rated at 1A output, with only 4.17uVrms noise, industrial best so far. I designed a TPS7A4700 PCB last night and placed the order today. Hopefully it works for Si570. Ian
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 Last edited by iancanada; 18th October 2012 at 12:02 AM. |
#1196 | |
#1197 |
That's my daily job, my hobby takes the advantage of
Ian - FIFO KIT & Si570 Clock Board GBIV http://www.diyaudio.com/forums/group...ml#post3372684 Last edited by iancanada; 18th October 2012 at 12:52 AM. |
#1198 |
Already apply free samples from TI, just hope it works as good as expected.
Ian
#1199 |
Ian, that looks like it could make a nice supply for the 'clean' side of the isolator boards too! (for those who may not want to add batteries).
Though I have to ask, why only one ground connector? Or is that a position for connecting ground wire between C6, C7 and R9? Last edited by hochopeper; 18th October 2012 at 01:15 AM. |
#1200 | |
That three pin connector is to connect directly to the on board socket. Isolator will be powered from Si570 clock board by the FPC/FFC cable, no need any additional connection. Ian
| XMOS-based Asynchronous USB to I2S interface | Lorien | Digital Source | 1722 | Today 01:29 PM |
| exaU2I - Multi-Channel Asynchronous USB to I2S Interface | exa065 | exaDevices | 1303 | 10th May 2013 05:19 PM |
| DAC chip selection + I2S jitter questions | drwho9437 | Digital Line Level | 2 | 26th July 2010 12:50 PM |
| Simple FIFO to I2S CPLD, for MCU players / reclocking | KOON3876 | Digital Line Level | 21 | 19th September 2008 04:00 PM |
| asynchronous reclocking and low jitter clocks | ash_dac | Digital Source | 3 | 8th February 2005 09:22 AM |
