Asynchronous I2S FIFO project, an ultimate weapon to fight the jitter
Old 26th September 2012, 07:42 AM   #1071
bigpandahk is offline bigpandahk  Hong Kong
Originally Posted by AR2 View Post
I am sure it was mentioned somewhere before, but for a late bloomers.... is there any source for rubber rings that you guys could recommend?
Thank you
I bought some nature rubber o-ring for the clock board. Photo at post #108 - Build Thread for TPA BIII + Ian Async I2S FIFO + OPC NTD1 + Salas SSLV
Drop me a PM and I can send you some.
Old 26th September 2012, 01:13 PM   #1072
GOR3 is offline GOR3  United States
Default LED Current
Ian, I am finally getting to the case work. Regarding the LEDs to indicate "locked" and the source selected (TTL, Coax, Optical), can the board power 20mA LEDs, or should they be low current types (i.e., 2mA)?
Thanks,
George
Old 26th September 2012, 11:46 PM   #1073
qusp is offline qusp  Australia
qusp's Avatar
why would you want a 20ma LED in a low noise environment? I presume its blue or white too? these are the highest noise too. very doubtful it would run it, not many receiver/logic chips have power for 100mA in LEDs...
the noise isnt a huge deal, but it all adds up, just seems unnecessary. do you know how annoying blue LEDs that bright are?
Old 27th September 2012, 12:52 AM   #1074
iancanada is offline iancanada  Canada
iancanada's Avatar
Thanks,
George
Thanks qusp,
The current limitation resistor on the s/pdif board is 1K for each LED. So, theoretically the current limitation would be 3.3mA. Roughly, if your LED is 2V, the working current will be 1.3mA . Small enough? Recommend high light version LED with color other than the white and blue.
Ian
Old 27th September 2012, 02:25 AM   #1075
qusp's Avatar
ya, I havent gotten around to casework that advanced yet, so didnt quote actual levels, but was pretty sure 20mA wasnt on the cards =) forgot about that schematic you posted
Old 29th September 2012, 01:38 AM   #1076
iancanada's Avatar
PCB order placed. Hopefully I can get all of the PCB samples by the end of next week. They are isolator, passive battery management and the Si570 clock board.
Ian
Old 29th September 2012, 01:44 AM   #1077
hochopeper is offline hochopeper  Australia
Ian, you are one unbelievably productive man!
Old 29th September 2012, 09:03 AM   #1078
TheShaman is offline TheShaman  Europe
Ian please keep us updated on the battery management board as well! I'm definitely interested.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 29th September 2012, 09:29 AM   #1079
wktk_smile is offline wktk_smile  Japan
wktk_smile's Avatar
I'm looking forward to see the reports from testers!
Old 30th September 2012, 03:46 AM   #1080
AR2 is offline AR2  United States
Master Burner
AR2's Avatar
Thank you bigpandahk,
no need to bother you. I have a source here and I already ordered a few. I appreciate it very much that you are willing to send.
Best
AR2
www.burningamp.com
Asynchronous I2S FIFO project, an ultimate weapon to fight the jitterHide this!Advertise here!
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3144 21st July 2017 12:59 PM
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1375 4th March 2017 07:58 PM
DAC chip selection + I2S jitter questions drwho9437 Digital Line Level 2 26th July 2010 12:50 PM
Simple FIFO to I2S CPLD, for MCU players / reclocking KOON3876 Digital Line Level 21 19th September 2008 04:00 PM
asynchronous reclocking and low jitter clocks ash_dac Digital Source 3 8th February 2005 09:22 AM
Copyright ©1999-2017 diyAudio
